synergie diesel hard work to start - bubbles fuel line
Stewart(oily)
x 35
Re: synergie diesel hard work to start
Unread post by Stewart(oily) »
Cheap and easy to replace all of the leak off pipes, not forgetting the "dead end" one, there are no seals on the steel injector unions, you either have a split pipe or a loose union, dropped glow plug nuts usually end up in Narnia :)
Harlequin
x 24
Unread post by Harlequin »
just a quickie - anyone know the diameter of the rubber fuel pipe from the bulb to the fuel filter?
x 94
Unread post by citronut »
here is a screen shot from service citroen
https://www.dropbox.com/s/be0ya89t92jqt ... 8.png?dl=0" onclick="window.open(this.href);return false;
No. 5 and 7 are from the primmer to filter
Regards, malcolm.
Harlequin
x 24
6mm pipes?
x 94
No. 6 on the drawing is from the filter to the pump, and the 6mm pipe under No. 6 is for LHD only,
i thought you were asking about from the primer to the filter 5 and 7 in the drawing?????? which look like 9mm and 7mm
Regards, malcolm.
Harlequin
x 24
sorry was at work - so the piping is 5+7+8+9 is the line from primer to filter.
ok so a 6mm inline 1 way valve wont fit as it`ll be too small?
Harlequin
x 24
replacing leak off pipes next - 1 way valve hasn't stopped the fuel pressure and poor starting
Harlequin
x 24
1 final bump - the air in the fuel line has reappeared - watching bubbles from filter housing through the clear pipe.
Harlequin
x 24
Re: synergie diesel hard work to start - bubbles fuel line
any ideas? primer needs 3 or 4 squeezes to firm , then itsoftens , and I can watch bubbles in the clear fuel line from filter housing to the pump.
change filter housing? fuel line after 1 way valve?
Xantidote
x 5
Unread post by Xantidote »
How good is the squeeze bulb itself - any signs of hardening/cracking? I seem to remember someone on forum replacing the bulb.
How flexible is the rubber hose? From experience, I had a problem with a length of the original rubber hose on my TD, between bulb & filter, albeit 1995 TD so quite elderly, which had become rather less flexible, and didn't like a change of angle where it passed through a support bracket when I'd been playing with the alternator. The net result was a crack on the inside of a preformed bend in the hose, allowing air in with suction, and squirting out when the bulb was squeezed. Easy remedy.
Are the hose clips Citroen originals, or has someone fitted a small jubilee clip somewhere in the line? I find with using jubilee clips on small diameter pipe, it's sometimes difficult achieving a good seal.
Martin
Harlequin
x 24
replaced the fuel line from the primer bulb to the fule filter housing
replaced fuel filter housing and O ring
no bubbles in fuel line!!
still wont bloody start without easy start
x 1469
Have you checked the valve clearances?
Harlequin
x 24
no because theres no room to get the rocker cover off , so if it needs that then its easy start forever
Xantidote
x 5
Well I suppose the good news is that you've got rid of the air bubbles, so that should at least have removed 1 reason for non-starting.
I was going to suggest you check the glowplugs, but I see you did that back at the beginning of the year. Might be worth checking that you've got power to the busbar, using either a multi-meter to check the voltage, or a bulb from busbar to earth. It's summer, but I'd still expect a TD to need 2-3 glowplugs to fire up, so if 1-2 glowplugs have failed in the last 6 months, you'd still get ignition with a bit of churning.
Martin
Harlequin
x 24
hmmm will take them out tommorrow
