Xantia oil change litres required
charentejohn
Re: Xantia oil change litres required
Unread post by charentejohn »
Well with my 4.5L to 4.8L fill up it is now showing mid way between max and min on the dipstick so looks ok to me.
Problem is the oil is so clear it is hard to see the level, I need to angle it so I can see the reflected light, but it is half way.
I am still amazed at how clean the oil is after a flush and since the latest change.
I realised, too late as usual, that I could have removed 0.5L from the 5L container using a measuring jug. That way I would have been sure it was 4.5L and not 4.5 ish. I will do it next time just to see what happens.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
