MOT Failure - Handbrake Efficiency 11%
citroenxm
Fallen Hero
x 70
Re: MOT Failure - Handbrake Efficiency 11%
Unread post by citroenxm »
Wow, I get around that in my manual Xantia HDi... Im not a fan of the Xsara, I couldn't live with one, I wonder how good it would do in the Xantia.... :-k
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
adjusting the cables will not give more effort at the pads but just reduce lever travel,
the mechanism in these calipers adjusts up with foot brake pressure and not hand brake operation
Regards, malcolm.
mirafioriman
Unread post by mirafioriman »
I guess it depends how far out of adjustment they are. If the lever came right up without the handbrake levers on the calipers being in the fully 'on' position then I guess it could make a difference.
It's always good practice to have everything adjusted correctly and within tolerances anyway so if the cables are incorrectly adjusted I would adjust them as a matter of course.
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
dandare1980
Unread post by dandare1980 »
UPDATE:
I managed to get it through by replacing the discs and pads with new ones. Not sure what efficiency it scored, but it was noticeably better than before.
Thanks for all your help and comments again.
Dan :)
1998 Citroen Xsara 1.9 D Estate (XUD9A indirect injection engine DJY with Bosch XUD 211 injection pump).
x 8391
Excellent news Dan :-D
