c5 turbo cut out
dawsy 22
Re: c5 turbo cut out
Unread post by dawsy 22 »
Hi the rod should be held in the opposite position to what it is when the engine is switched off I am not sure which pipe to block but try to find which one goes towards the rear of the engine failing that block 1 off and see how you go if know luck try 2
Thanks Ian
pavlebo
Unread post by pavlebo »
I closed vertical pipe. Now, no limp mode, no asp, no antipollution error. I ordered new swirl valve.
Thanks!
