Citroen c3 picasso
Huskyxantia
x 900
Re: Citroen c3 picasso
Unread post by Huskyxantia »
mickthemaverick wrote: 19 Dec 2024, 21:35
Huskyxantia wrote: 19 Dec 2024, 21:32 If not think i'll get a bmw 3 series . ( diecast one ) lol
Go wash your mouth out!! :-D
:rofl2:
:-D
x 8353
I just cannot get my head around this Husky... There must be something we're all missing here.
Can you determine the failure mode of the master cylinder and is it the same for all that have failed? Knowing how it's failed may help us establish why perhaps...
Huskyxantia
x 900
Hi Jim, ok, your in the car just started the engine, foot down 1st gear , pedal flat to the floor
:-D
Huskyxantia
x 900
Or your in gear , getting ready to either pull up at the lights or other place you need to stop , push pedal down to go down gear , pedal wont come back up , car stuck in gear, turn off engine , pull car out of gear, then no pedal so cant use gear stick as no clutch.
The wife has stepped up shes got a much more exsensive one in order £85 with a smalk discount was over 100, its got a 5 yr warrenty & if it fails either replacment or refund will happen, i still reckon ALL these below £30 ones are fake ? Maybe, i thought the brake booster might be naff , but nope it works as it should , when this more exspensive bit turns up , were see what happens. Ive put a new slave on the gear box , only to find out the one i took off was ok , but the new one can stay.
:-D
Huskyxantia
x 900
Oh Just remembed, the day before this i pushed the clutch pedal down to be greeted with a loud snap,clonk , sort of spring sound . Also yesterday i unplugged the master off the clutch pedal & worked the plunger by hand i felt it had an inch of pressure then , it goes , so doing that then gave me the answer , master gone again.
Anyone reading this for the first time , sorry abiut my spelling my fingers are like bananas , but .. the clutch master cylinder is connected to the clutch pedal, the slave is on the front of the gear box, geavity bleeding does not always work as i have found out , 2 man is good & the vacum method too.
:-D
Huskyxantia
x 900
Dpf issue just found this not ment for what im doing but here for reference when needs be
:-D
Huskyxantia
x 900
If the slave goes then do this , mines not this part
:-D
x 8353
Ahh, so are all the failing ones cheaper non-OEM then? eBay specials? That might well point to a potential quality issue.
Have you had any of them apart to try and see what's failing in them?
No worries about banana fingers - I only get by with much use of a spell-checker ;)
Huskyxantia
x 900
Theres not really much to the part , id say a syring is a better design over these parts , let me post ones for sale.
:-D
Huskyxantia
x 900
:-D
Huskyxantia
x 900
:-D
Huskyxantia
x 900
Then top of the shop with warrenty & so on,
https://www.ebay.co.uk/itm/175568886382 ... edia=EMAIL
Which has changed listing e.g. Price & disount stuff , it now just shows £73.99 , with no other mention of price reductions
:-D
Huskyxantia
x 900
:( :( :) Makes me wonder as Nappa & Luk , ithought they were ment to be a good brand , seems they are the cheapest around , market ploy ? Or a fast way of outing rubbish, ive sent 2 back now & both returns no hassle at all .... make you wonder if they know there stuff is rubbish
Im worried that fitting a new one & it happens again then what ?
:-D
Huskyxantia
x 900
As for service part , dont think you can repair them looking at one i photographed not long after i got the car it looks to me as if they could do with a better type of seal , no wonder why air gets in.
:-D
x 8353
Hmmm. LUK should be OK, an OEM and their clutches always used to be fine - I've fitted a few... They seem to be too cheap though and the possibility of them bring fakes at this price point can't be discounted... It seems so much stuff is these days...
Febi should be good and the price is nearer what what I'd expect... And having a warranty suggests it's of known provenance and quality...
I must say, for a master cylinder, they do look a bit flimsy...
