x 8370
MattBLancs wrote: 27 Oct 2023, 04:20
Helping a friend nice house tomorrow (reckons he'll not need the C5 boot space, we'll see how fast the Transit Luton fills up :) )
He will!
MattBLancs wrote: 27 Oct 2023, 04:20 .... And currently awake at 4 in the morning as my littlest is full of a cold :zzz: poor little chap
He and I too :( Post-Saunter Lurgy :twisted:
May he soon be on top form :)
x 2341
Unread post by MattBLancs »
MattBLancs wrote: 25 Oct 2023, 11:30 the HDi Coupe's auxiliary belt is A LOT more tired than it appears from above!
6pk 1738 says the parts Asia site. For info: micro Vee belt, 6pk = 6 grooves on the pulleys
Amazed how expensive the belts seem to be now! I'm sure I've paid say £5 - £7 or so previously, Eurocarparts is asking £23 for example!?!?
Kept digging! 6pk1738 belt, bought £7.75 including delivery - that's more like it 😁
x 2341
CitroJim wrote: 27 Oct 2023, 05:44 He and I too :( Post-Saunter Lurgy :twisted:
Get well soon too Jim :)
x 8370
MattBLancs wrote: 27 Oct 2023, 08:53
Thanks Matt :D Another therapeutic 5K run has helped :) Honestly, I'd recommend anyone who's feeling a bit below par to go out for a run. I guarantee you'll feel much better for it :D
Their powers seem much enhanced if done in the dark ;)
c16rkc
x 104
Unread post by c16rkc »
Sorry to hear about your little one... sadly it's that time of year.
It's when they get the tickly cough it's the worst, as the little ones don't seem to understand what's happening to them, and can get a bit panicked. Hope we don't get that going around this year...
x 2341
Ready for the exchange, helping my mate move house today
x 1068
Unread post by Rp0thejester »
What happened to him not needing your boot space?
x 2341
Rp0thejester wrote: 27 Oct 2023, 19:57 What happened to him not needing your boot space?
We've known each other a long time - I've a pretty good handle on when to ignore him! :-D
Left home at 09:10, just got back home now (22:05) apart from 30 minutes or so when we stopped for (Dominoes) tea about half eight, have been on my feet and shifting stuff all day.
Cream crackered!
x 2341
Damper primed.
Rather chilly (10°C) but hopefully will dry ok for a quick brush on black top coat later. Various bits on the underside of the wheel arch also treated too
This is worst spot, thankfully cleaned up ok. Now also repainted:
x 2341
Comparison:
Top, rusty disintegrated upper spring carrier from 2002 HDi Coupe. About 158,000 miles
Lower, as found spring carrier from 2000 2.0 Coupe. About 169,000 miles.
Rusty top (balanced in top of complete strut from 2000 Coupe)
Am going to put the (originally AL4 equipped but all alloy engine EW10J4) strut complete onto the HDi Coupe in the short term. Will rebuild / repaint the HDi struts and new springs. Different part numbers but hopefully spring rates not that far apart (will see soon enough!)
x 8370
Gosh Matt, those upper spring carriers were approaching dangerous with all that corrosion... The worry is they escape MoT scrutiny as they cannot be readily seen...
A bit like Xantia/XM strut tops... They can get very bad before the MoT man might notice...
x 1068
The only dangerous thing that I could see was that grinning crazy man....
x 2341
CitroJim wrote: 28 Oct 2023, 19:08 Gosh Matt, those upper spring carriers were approaching dangerous with all that corrosion... The worry is they escape MoT scrutiny as they cannot be readily seen...
Yes very much hidden when on the car, you can imagine quite how much my heart sunk when I pulled the strut down our the arch and saw that!!
Springs have had an advisory for corrosion for a couple of years, that's why I'm changing them, but the upper seat being so far gone was a big shock.
Agree not far off catastrophic collapse I'd guess.
Rp0thejester wrote: 28 Oct 2023, 19:10 The only dangerous thing that I could see was that grinning crazy man....
Oh don't worry about that nutter, he's harmless.
:rofl2:
Realised that "selfie mode" and peering in from above was best way of getting an image there, but then realized I was going to be in shot no matter how I angled it, so gave it my best cheesy grin
x 2341
Knackered auxiliary belt off. A ten millimetre longer belt (1750 Vs 1740, actually Vs supposed correct length of 1738!) Seems very tight to get on.
Belt routing (memory jogger!)
Have taken idler pulley off (as can be easier to install new belt with the pulley) and though no play or roughness have popped the dust seals off and will replace the "cheese" that once was grease!
Old grease
Old grease
2.0 coupe strut given quick wire brush and slap some paint on
x 2341
Probably worth keeping as a spare, no? :rofl2:
