Citroen Zx16v
bxzx16v
x 34
Re: Citroen Zx16v
Unread post by bxzx16v »
It certainly is Jim , any excuse to drive it now :wink: .
Mark
bxzx16v
x 34
Re: Citroen Zx16v
It all seems to happen once , I've got the insurance to sort out and it's MoT time too , first up an oil & filter change and hope for the best .
Mark
Citroenmad
x 110
Re: Citroen Zx16v
Unread post by Citroenmad »
How did the MOT go Mark?
I've got my Activa to put through an MOT next month, hopefully it'll all be fine.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
bxzx16v
x 34
Re: Citroen Zx16v
It's booked for Friday morning Chris , fingers crossed :| .
Mark
bxzx16v
x 34
Re: Citroen Zx16v
Took the car in this morning but it was a fail , weak handbrake efficiency . It's more than likely due to lack of use and the self adjuster has seized , anyway I've got some new rear pads to go in whilst the wheels are off . I'll take her back for a re-test next week when I'm on afternoons and alternate usage between the Zx and the Laguna .
Mark
Citroenmad
x 110
Re: Citroen Zx16v
Thats not too bad Mark and should be an easy fix :)
03 Seat Arosa 1.0S
bxzx16v
x 34
Re: Citroen Zx16v
Yes not too bad Chris , it's getting sorted in the week and back for a free re-test at the end of the week . I really must use it more than what I do really , it's just easier to just jump in the Laguna sometimes though .
Mark
x 8437
Re: Citroen Zx16v
Mark, yes, use it more. Not using them does more harm than careful regular use in my experience...
Still, not a bad fail by any means...
bxzx16v
x 34
Re: Citroen Zx16v
I've managed to make a start today on a job I've been wanting to get done for ages , that is removing the spare wheel cradle and getting it cleaned up and repainted . My original plan was to take it to work and get the angle grinder with a flap disc and clean it that way . Then I thought I could get it shot blasted and it would be quicker and make a better job , anyway after 20 minutes in the blaster the cradle looks fabulous , transformed from crustiness to nearly as good as new . It will be receiving a couple of coats of bilt hamber electrox zinc primer followed by two coats of satin black . I have also got a brand new cradle hook which maybe going on too . While the cradle & wheel are out of the way I've got a few bits to tidy up underneath , there's a couple of very tiny sections on seams where the factory applied coating has de-laminated slightly . I'll get some pics up when I make a start which could be tomorrow .
Mark
daviemck2006
x 485
Re: Citroen Zx16v
Unread post by daviemck2006 »
Where did you get the cradle hook Mark? The experts cradle, which has the spare on it is held up with a cable tie round the cradle, and round a nut on the top. Not the best idea! I would presume the cradle hooks are all the same for the zx and expert.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
bxzx16v
x 34
Re: Citroen Zx16v
A friend of mine used to work for a Citroen dealer and he had a load of bits in his shed that he let me have , I would imagine that the dealers stock these still ? Is it just the hook your missing or has the long bolt with the slot in gone too ?
Mark
daviemck2006
x 485
Re: Citroen Zx16v
Just completely missing. Nothing there at all. One cable tie round cradle, fed up through the hole, through a nut and back down to the cradle. Not the best solution, but works. At least it is a big cable tie, but not a lot really holding up the spare.
Peugeot boxer 2016
In the family
bxzx16v
x 34
Re: Citroen Zx16v
I managed to get two coats of zinc primer on the cradle today , tomorrow I'll be getting some satin black on . I'm even considering having the spare wheel shotblasted as it's done such a good job on the cradle , I tidied the wheel up last year with an angle grinder and flap disc but it's not a patch on this . I'll not want to put them back under the car when their done #-o .
Mark
bxzx16v
x 34
Re: Citroen Zx16v
I've just been on with machine polishing the Zx , all I can say is WOW , I've done the bonnet and down the drivers side and gloss and reflectivity is amazing . I'll just see if I can get some time to finish the rest off , I'll get some pics up later .
Mark
daviemck2006
x 485
Re: Citroen Zx16v
Sounds good Mark, it is a lovely car. I hope my c4 is in such nice condition in 10 years time!
Peugeot boxer 2016
In the family
