Davie's Activa Clutch
x 1498
Re: Davie's Activa Clutch
Yes, NFP; was last listed at £553 :shock: :-D
superloopy
x 19
Unread post by superloopy »
Is that part specific to the activa or just general across all the hydraulically operated clutch models?
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
x 1481
Unread post by xantia_v6 »
Common across hydrauc clutch models. RHD and LHD àre obviously different, in about 1999, LHD models got a revised master cylinder with a separate reservoir that sits between the LHM tank and the ABS block.
superloopy
x 19
Thanks for that. I've got about 4 in the shed, a couple of new ones in there too. Just a bit of a hoarder .... "they'll come in useful some day "
Mike
x 8437
Gearbox driveshaft seal has arrived... Sunday or Monday will see it fitted...
x 8437
RichardW wrote: ML5 32x50 x 10
Just checked the new one I've received. It's the correct one so I'll fit it later this afternoon...
RichardW wrote:Surprised it held in the housing!
At least it'll make it easy to remove... That's if it even needs removing... I'd not be surprised if it comes out with the shaft!
More later... Weather permitting...
x 8437
An ultimately frustrating day today.. Got the driveshaft out no problem, old seal popped out without too much issue (it is the wrong size) but...
I just can't get the driveshaft back in without assistance as the hub with disc, caliper and new pads is just too heavy to manoeuvre accurately enough on my own to avoid the risk of damaging the new seal :evil: Previously I did the job with a bare hub... I'm very reluctant to strip the hub again...
I have sent out for assistance... Should only take an hour tops, with tea served... Not sure when the assistance will arrive just yet but all I know is that with those driveshafts so firmly stuck into the hubs has been a constant source of aggro all the way through this job :evil:
Still, almost there...
x 3298
Jim, if your assistance doesn't get there today, give me a shout. I have Tuesdays and Wednesdays off, so I can lend a hand with muscles (but not much intelligence).
daviemck2006
x 485
Unread post by daviemck2006 »
Your a bit like me James. Only better cos I've knackered back and hands to go with the no knowledge [emoji13] [emoji23] [emoji15]
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Zelandeth
x 1607
Unread post by Zelandeth »
You've got my number Jim if I could lend a useful pair of hands. Drop me a text or PM if I could be handy, no particular plans tomorrow aside from trying to finish turning the Saab back from a matt finish to gloss after it had a run in with TFR a few weeks back and had all the wax stripped off!
Sure I could be spared for an hour or two to help.
Current fleet:
x 8437
Thanks all... Won't be any time soon I'm afraid. I have other things that must take priority...
x 3298
That sounds ominous. I hope that either I am wrong, or that things take a turn for the better.
x 8437
Hell Razor5543 wrote:That sounds ominous. I hope that either I am wrong, or that things take a turn for the better.
Very much the former I'm afraid James... Here teetering on a knife-edge... Not so much dad but me... I'm in danger of doing exactly what I fear my Activa might do any time between here and Somerset...
x 3298
I would say try and take things easier, but what with the situation that will be difficult. Keep us abreast of things, and I know that forum Members will help out where they can. I can help out for the next 2 Tuesdays and Wednesdays, but I am then unavailable for a fortnight, although after that I can help again.
Fingers crossed all will start looking up.
x 8437
Thanks James, that's appreciated :D
