x 8409
Re:
addo wrote:You'll slide backwards into a 2CV at this rate. Small, revvy, Spartan... Can you see where this is leading? :mrgreen:
I can Adam but I promise I won't :lol: :lol:
The C1 does have a bit of 2CV/R4 about it though... And none the worse for it either...
Had a call from my dealer last evening. The replacement pipe for my V6 is on back-order and at least a couple of weeks away. Pavlos, you were lucky!!!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I "skinned" the return junctions and used regular oil/fuel hose with clips. Under the black plastic overmould are white barbed connections. Almost any broken harness can be reused this way.
KP
x 27
Re: Citrojim's Xantia and XM Tales
Unread post by KP »
I suggested a copper t piece made to the right size to replace the junction. That is the item fails the most so would remove the biggest failure point :)
x 8409
Indeed Will, entirely reasonable and the reason I'm hanging on to the duff ones. They'll inevitably be NFP in the not too distant...
x 8409
First fuel consumption check on the C1....
Do bear in mind I've been driving it like I stole it...
57mpg
8-) :-D :P
Chris570
x 36
Unread post by Chris570 »
yes but to be fair you only have 3 injectors working
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
KP
x 27
Unread post by KP »
Ha ha like it Chris!
But that's pretty decent Jim.
I'd love to know what it's like driven gently?!
Guessing it weighs about 700kg as well with no electrics inside it ;)
x 8409
Chris570 wrote:yes but to be fair you only have 3 injectors working
True! And only three pistons too!!!
I shall try driving gently for a tankful and see.. It'll be hard mind. It just begs to be driven with some spirit :-D
Will, 800Kg so not far off... I only add 68Kg to that..
KP
x 27
Unread post by KP »
That can't be far off the original minis to be fair. I would how a two pot diesel would do in them as it would have enough torque with a turbo for that size of car, could crack 100mpg then and be rfl free for a good few years as well as the gov keeps bringing the threshold down...
x 3296
IIRC the Daihatsu Charade diesel could do 100MPG on a tiny engine.
Northern_Mike
KP wrote:That can't be far off the original minis to be fair.
I'd expect it to be *way* better than an original Mini. They were from the days when 30mpg out of a 1.6 was acceptable. I hardly ever got 40mpg out of my Metro with the 1275cc and SU carb, and mini owning friends used to reckon 35-40mpg and no more. Horrific little cars. The guy I helped out after school in his garage when I was a kid was a Mini specialist. Put me off the bloody things for life. Hilarious to be a passenger in when they were being driven fast though.
KP
x 27
Unread post by KP »
I meant weight wise :)
Northern_Mike
KP wrote:I meant weight wise :)
Ah, my mistake. Yes, not far off. I think they were about 670kgs. Just think how much safer and better a C1 is, and only for an extra 100kgs or so..
KP
x 27
Unread post by KP »
Very true indeed :) still think the French should do what they do best and stick a nice tiny turbo diesel in there...
Northern_Mike
I thought all small French cars either had to be powered by a tappety pushrod lump or the 1360cc inline 4? :shock:
