x 2218
Unread post by MattBLancs »
Rp0thejester wrote: 18 Jul 2026, 23:00 Tow bars always worries me, it tends to mean the engine has been under a lot of strain already. I'd rather stay clear.
Double edged sword isn't it - can be anything from regularly dragging a big caravan / a car carrying trailer, close to the car's rated capacity, behind it down to a little toy "hobby" trailer like mine: 45 kg empty, filled with say camping gear it still might weigh less than all 5 seats occupied. Or indeed bike racks - I understand some electrical cars for example can have "towbars" that are only actually rated for use mounting bike racks!
There's also the case, given the age of the cars I'm considering, that first owner had the towbar added and subsequent owner(s) have never used it during their ownership.
Double edged as you can see from this blog I'd almost certainly get good use out of another towbar equipped car :)
Folks also can be quite variable in how kind they are to their clutches (and the car generally!) so how long clutches last has a broad range!
x 7908
MattBLancs wrote: Yesterday, 19:17
Never a truer word has been written. Back in the day I bought my wife a brand new Skoda Estelle and myself a 2 year old Estelle with 14000 miles on the clock. In the next three years her car needed two clutch replacements while mine needed none. At the end of those years I sold both cars, hers being 3 years old with 17000 miles and mine being 5 years old with 74000 miles!! Draw your own conclusions!! :-D
x 2218
Hello readers!
Opinions please on this long winded MOT history and my thoughts that follow:
(Spoiler for neatness)
Spoiler: show
MOT valid until 15 February 2027
MOT history
Date tested 16 February 2026 PASS
Mileage 196,452 miles Expiry date 15 February 2027
Repair as soon as possible (minor defects):
Nearside Registration plate lamp inoperative in the case of multiple lamps or light sources (4.7.1 (b) (i))
Monitor and repair if necessary (advisories):
Front Brake disc worn, pitted or scored, but not seriously weakened N/S & O/S (1.1.14 (a) (ii))
22 January 2025 PASS
Mileage 193,230 miles Expiry date 1 February 2026
Offside Front Anti-roll bar linkage ball joint has slight play (5.3.4 (a) (i))
Offside Front Suspension arm pin or bush worn but not resulting in excessive movement lower arm inner bush (5.3.4 (a) (i))
Nearside Rear Tyre worn close to legal limit/worn on edge on limit 1.6mm (5.2.3 (e))
Offside Rear Tyre worn close to legal limit/worn on edge (5.2.3 (e))
Rear Coil spring corroded n/s&o/s (5.3.1 (b) (i))
Front Service brake fluctuating, but not excessively n/s&o/s (1.2.1 (e))
22 January 2025 FAIL
Repair immediately (major defects):
Exhaust emissions exceed manufacturer's specified limit (8.2.2.2 (a))
Registration plate lamp inoperative in the case of a single lamp or all lamps (4.7.1 (b) (ii))
29 January 2024 PASS
Mileage 188,042 miles Expiry date 1 February 2025
Offside Front Tyre worn close to legal limit/worn on edge on limit 1.6mm (5.2.3 (e))
Nearside Front Tyre worn close to legal limit/worn on edge (5.2.3 (e))
Rear Tyre worn close to legal limit/worn on edge n/s&o/s (5.2.3 (e))
29 January 2024 FAIL
Offside Front Coil spring fractured or broken (5.3.1 (b) (i))
23 January 2023 PASS
Mileage 178,971 miles Expiry date 1 February 2024
Offside Front Wheel bearing slightly noisy (5.1.3 (b) (i))
Date tested 2 February 2022 PASS
Mileage 172,034 miles Expiry date 1 February 2023
Date tested 24 November 2021 FAIL
Mileage 172,010 miles
Parking brake efficiency below requirements (1.4.2 (a) (i))
Date tested 14 October 2020 PASS
Mileage 165,308 miles Expiry date 13 October 2021
Nearside Rear Brake cable damaged but not to excess (1.1.15 (a))
Offside Rear Brake cable damaged but not to excess (1.1.15 (a))
Nearside Front Anti-roll bar linkage pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i))
Date tested 14 October 2020 FAIL
Mileage 165,286 miles
Do not drive until repaired (dangerous defects):
Offside Rear Tyre has ply or cords exposed (5.2.3 (d) (ii))
Date tested 12 April 2019 PASS
Mileage 157,473 miles Expiry date11 October 2020
Date tested 19 March 2018 PASS
Mileage 149,959 miles Expiry date 19 March 2019
Date tested 9 March 2017 PASS
Mileage 137,177 miles Expiry date 19 March 2018
Advisory notice item(s)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Date tested 9 March 2017 FAIL
Reason(s) for failure
Offside Rear Registration plate lamp not working (1.1.C.1d)
Front registration plate faded (6.3.1d)
Nearside Rear Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Offside Rear Anti-roll bar has slight play in a pin/bush (2.4.G.2)
Date tested 9 March 2016 PASS
Mileage 99,106 miles Expiry date 19 March 2017
Date tested 9 March 2016 FAIL
Nearside Registration plate lamp not working (1.1.C.1d)
Short version is I'm feeling "disenfranchised" with the thought of ploughing a load of money into a more valuable ** car.
** Read "more valuable" as 4-5 grand.
Instead I'm wondering about a cheap £1000 example that ticks some of the boxes, keeps me away from Adblue issues for the moment. I'll keep a watching brief on Manchester ULEZ plans and get something reasonably economical, with lots of space.
Enter stage right:
https://www.autotrader.co.uk/car-detail ... 6flrfc%3D1
£1000, 200k miles. Generally looks in good condition, other than a worn gear knob.
The above MOT history to my eyes looks initially frightening but also seems to show a car that is "chucked in for the test, as is" but then fixed and off to give another years service. Save for a persistent offside numberplate bulb, almost none of the faults / advisories return the following years.
200k likelihood of: original clutch, DMF, timing belt, DPF???? I would guess most if not all have been replaced once if not more.
Other info: road tax £170, boring black, EURO 5, no towbar. Think has the glass roof. Allure spec. Sat Nav.
x 7908
Not into great detailed descriptions at the moment but from reading that MOT history I'd describe it as unloved and wouldn't buy it!! :)
x 7908
A cheap fill in until your situation is sorted? :)
https://www.ebay.co.uk/itm/366528016871
x 2218
mickthemaverick wrote: Today, 16:45 Not into great detailed descriptions at the moment but from reading that MOT history I'd describe it as unloved and wouldn't buy it!! :)
I've had a dig into that particular example's seller (and the reviews of the business are very, err, variable!!) - at present that aspect is the big fly in the ointment for me (particularly when it's a couple of hours away from home)
Agree it could be neglected, but also think some folks do a sort of "see what it needs" approach to the test. To me, checking tyres and bulbs ahead of the test is a no brainer 10 minute check "why wouldn't you" but I've also seen many car MOT history logs with these basic faults present when presented for test! Odd, isn't it! :?:
Thanks Mick for the 307 suggestion, something to consider. I suspect I might jump up to say:
£1700 and up the economy + towbar + (a bit!) newer this one:
https://ebay.io/m/FYgT87
(2012 308 SW 2.0 HDi, Allure) 55 miles / 1 hour from home.
The 307 is a bit further to travel: again towards Birmingham and 92 miles / 1.5 hours from home
x 992
Unread post by Rp0thejester »
Am I seeing things or has someone repainted the alloys and then kerbed it?
