C3 Phase I random starting issues
frenchc3
Re: C3 Phase I random starting issues
Unread post by frenchc3 »
Hi @ozvtr,
Thanks for the feedback. Another problem might be the tension in the accessories belt. How would I go about tightening the belt, I can't find any video. Do I simply increase the torque on the tensioner central bolt?
thanks
ozvtr
x 256
Unread post by ozvtr »
I'm sorry but I'm not familiar with the tensioner on the stop start.
However the standard engines had two types of tensioners. The engines built before 2004 had a lead-screw adjuster. Tension was adjusted by turning the lead-screw and locked in position by the bolt in the center of the pulley bearing. The other type had a spring inside the tensioner and the tension was automatically adjusted.
If you cant see the lead-screw (looks like a very long bolt going up and down) behind the tensioner pulley, I'd say it's the spring loaded type and there is no adjustment.
