C4 auto lock/unlock
Serbian
Re: C4 auto lock/unlock
Unread post by Serbian »
Marc,
I have made the required payment. Give me a list of everything the car has and doesn't have (factory build sheet)..
VIN: VR7**************[VIN obfuscated, can be read by forum staff]
Thank you.
Filip.
x 6950
Thank you for your Forum donation.
Here is the build sheet:
Vehicle Characteristics
Vehicle familyC4 X (C43)
AS/RP N°17185 82 1 0214
Warranty Start Date02/02/2024
Engine serial number10 Q3DP 1858455
OPB00T9
BERe9*2007/46*6816*18
P4A9833939699
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC4 X (C43)
SILHOUETTE4-DOOR SALOON
TRIM LEVELCOMMERCIAL VEHICLE LEVEL 2 PSA
ENGINEDV5RC UE64 1.5 L DIESEL
TRANSMISSIONSTT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPEPAINTED METALLIC EXT TRIM TYPE
BODY COLOURBLACK PEARL PAINT
INTERIOR TRIM TYPEPREMIUM LEATHER UNIVERSAL TRIM C41
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)ATNG8 AUTOMATIC GEARBOX WITHOUT ELECTROMAGNETIC PUMP
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)DV TYPE ENGINE
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
Fuel Supply-Engine
DRIVE BATTERYWITHOUT TRACTION BATTERY
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 6.4 ENGINE EMISSION CONTROL
EXHAUSTMUTE EXHAUST
CAPACITY1500 CM3
CATALYTIC CONVERTERWITHOUT CATALYST
FUEL TANKNON-PRESSURISED FUEL TANK WITH LOCATING TAB
FUEL TANK INSULATIONWITHOUT FUEL TANK INSULATION
COOLING MOTORRADIATOR 21DM2 - EP21
CRANKCASE GAS CIRCUIT HEATINGWITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)ENGINE POWER 96KW - 300NM
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.4 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1E 2VTS 140W AERO SHORT NOZZLE
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERWITHOUT RESERVOIR FILTER
STOP AND STARTWITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIOFINAL DRIVE RATIO 15 X 58
WHEEL STYLE18-INCH ALLOY C41
RIM/TYRE SIZE18 INCH TYRE FITMENT
TYRE (SIZE, TYPE)195/60 R18 96H - NOT FOR DIFFICULT ROAD CONDITIONS
WHEELS FITTEDWHEEL 6.5J18ET27
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPEATN8 TYPE GEARBOX
Suspension-Steering-Brakes
BRAKING ASSISTANCE IN REVERSE GEARWITHOUT REVERSE GEAR BRAKING ASSISTANCE
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
ANTI-THEFT DEVICEWITHOUT STEERING LOCK
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR DIAMETER 22 HOLLOW
BRAKES (CIRCUIT)REAR DISC PROTECTOR
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
BRAKE ASSOCIATED VARIANTCONTI MK100 ESP
Body Fittings
TOWBARWITHOUT TOWBAR
AERIALREAR SPOILER AERIAL + DIGITAL + GPS + GSM
FINISHER (SELF-ADHESIVE)GLOSS BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE)SILVER GREY SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE)BLACK CENTRE CAPS+BLACK BOLTS DESIGN
EXHAUST TAILPIPECHROME PLATED EXHAUST TAIL PIPE
UNDERBODY SHIELDFRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION
INDICATORSLUMINOUS SIGNATURE
WASHER JETWINDSHIELD WASHER JET WITH DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTIONELECTRIC FOLDING EXTERIOR MIRROR+DIODE
SPLASH SHIELDACOUSTIC FRONT + REAR MUD GUARDS + FRONT RIGHT-HAND EXTENSION
EXHAUST TAILPIPE TRIMW/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFINGSOUNDPROOFING UNDER BONNET + BULKHEAD + SERVO
WINDSCREEN GLASS (TYPE)HEATED WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
BUMPERBODY COLOUR BUMPER+GRAIN BLACK FRONT/GLOSS BLACK REAR SKIRT
FRONT FOGLAMPLED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AIDVIDEO PARK 2
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESBODY COLOUR EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)WITHOUT EXTERIOR MIRROR SPECIAL FEATURE
SUN ROOFSUNROOF SEQUENTIAL ASSISTED CONTROL + ANTI PINCH
BUMPER TRIMSILVER GREY FOGLAMP TRIM
GLASS (APPEARANCE)TINTED + DARK-TINTED RR WINDOW GLASS
HANDS FREE ACCESS AND STARTINGFRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR SEATFX ONE-PIECE REAR SEAT+2/3-1/3 FOLDING SEAT BACK
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
REAR SEATBELT3 PYRO RETRACTORD + SEATBELT FASTENED TELL-TALE
FRONT SEATBELTREEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER
CLIMATE (AMBIENT TEMP)COLD COUNTRIES
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
GEAR SELECTORGEAR SELECTOR AT THE FLOOR AND AT THE STEERING WHEEL
GRAB HANDLESFRONT + REAR HANDLES
CONSOLEUPPER TRIM
DRIVING POSITIONLEFT-HAND DRIVE
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGGLOVEBOX+LED FRONT CONSOLE
DASHBOARD EQUIPMENTSLUSH GRAIN BLACK IDENTITY
INT. TRIM AND EQUIPMENT VARIATIONSTANDARD INTERIOR EQUIPMENT DRESSING
MISC. INT. LAMPSLESS INTERIOR LIGHT
INSTRUMENT PANEL (CHARACTERISTICS)INSTRUMENT PANEL WITH MATRIX+WHITE AMBIANCE
DOOR TRIMWITHOUT LINING
LOUDSPEAKER5 FR SPEAKERS+2 RR SPEAKERS+1 BASS BOX
POLLEN FILTERWITH POLLEN FILTER + ACTIVATED CARBON
LANE KEEPING MANAGEMENT ASSISTANCELPA WITHOUT HIA DELEGATION
PASSENGER COMPARTMENT SOUNDPROOFINGSOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT TILTING BACK ERGONOMIC ELECTRIC LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTERGONOMIC ELECTRIC TILT BACK LUMBAR SUPPORT
FRONT SEAT ARMRESTFRONT CENTRAL ARMREST
FRONT SEAT ARMREST (OPERATION)FRONT ARMREST MANUAL
SATELLITE NAVIGATION SYSTEMCONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBSECO LED
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERLKA STRUCTURAL EDGE
DISPLAY10-INCH COLOUR HD TOUCH SCREEN
MISC. INT. ACCESSORYPORTABLE SUPPORT
COURTESY MIRRORDRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
OIL GAUGEW/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTDRIVER + R1 PASSENGER HEATED SEAT
FRONT LATERAL AIRBAGFRONT CHEST SIDE+REAR CHEST/HEAD CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER + FR PASSENGER FOOTWELL LIGHTING
HEATING DUCTFRONT+REAR PILLAR+REAR VENTILATION
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
WIFIWITHOUT WIFI
STORAGE (DRIVING POSITION)GLOVE BOX + DRAWER
RADIO RECEIVERANALOGUE + DAB RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROLDRIVER’S SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS)PLAIN STORAGE POCKET
CARPET COVERWITH CARPETMAT
OBSTACLE DETECTION SYSTEMFRONT/REAR/SIDE RADAR OBSTACLE DETECTOR + TRAJECTORY
TRIM ADAPTATIONWITHOUT MOULDING ADAPTATION
RADIO FREQUENCYRADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
LOCKING CONTROLNORMAL + AUTOMATIC LOCKING
STEERING WHEELFULL FLOWER LEATHER ST WHEEL
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
AUDIO PACK AUXILIARY SOCKETAUDIO PACK AUXILIARY SOCKET 1 USB TYPE C
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR CLASS 18 HEA
BATTERYL3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTORSTTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
BATTERY CHARGERWITHOUT ON-BOARD CHARGER
MULTIPLEXINGR3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUGWITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS)CONDENSER 20DM2 - THICKNESS 12 CLASS 2
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
TRAFFIC SIDEDRIVING ON THE RIGHT-HAND SIDE
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
SLAVE CONTROL UNITBSI + COM 2020
the2ems
x 10
Unread post by the2ems »
Update on the auto lock/alarm activation. I’ve just been to the dealer on an unrelated issue, but whilst there I mentioned about the alarm going off when I left my wife sitting in the car, while I went into a shop with the keys. Now the owners manual states that “The alarm does not activate when locking automatically from a distance” But mine does. The person I spoke to went to talk to the service manager, who apparently has the same model as me, and his does the same. 🤔
CITROEN C4 1.2 PURETECH C-SERIES EDITION S/S 5DR (2023)
x 6950
Personally I think it's a bit of a daft idea to be honest, as logically I would want it to lock and arm the alarm if this is the intention, otherwise what's the point if you have to unlock it and re-lock it after auto locking to arm the alarm that way?
Accepted that it is not ideal if you are leaving a passenger or animal in the car for short periods and it locks on walking away. I suppose you'd have to deactivate the volumetric protection before you did, so it doesn't set of the sensors from inside movement.
Perhaps you should just get the auto locking deactivated by the dealer whilst there and be done with it, relying on the fob to lock / arm and unlock/ disarm?
the2ems
x 10
GiveMeABreak wrote: 23 Oct 2024, 15:18
Is that something they can do?
x 6950
They may well be able to, as they can disable the hands-free element of most of their vehicles, so a possibility you may want to ask about.
the2ems
x 10
GiveMeABreak wrote: 23 Oct 2024, 17:25 They may well be able to, as they can disable the hands-free element of most of their vehicles, so a possibility you may want to ask about.
I’ll certainly bear it in mind.
