Marc,
I have made the required payment. Give me a list of everything the car has and doesn't have (factory build sheet)..
VIN: VR7**************[VIN obfuscated, can be read by forum staff]
Thank you.
C4 auto lock/unlock
- x 6950
Re: C4 auto lock/unlock
Thank you for your Forum donation.
Here is the build sheet:
| Vehicle Characteristics | |
| Vehicle family | C4 X (C43) |
| AS/RP N° | 17185 82 1 0214 |
| Warranty Start Date | 02/02/2024 |
| Engine serial number | 10 Q3DP 1858455 |
| OPB | 00T9 |
| BER | e9*2007/46*6816*18 |
| P4A | 9833939699 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C4 X (C43) |
| SILHOUETTE | 4-DOOR SALOON |
| TRIM LEVEL | COMMERCIAL VEHICLE LEVEL 2 PSA |
| ENGINE | DV5RC UE64 1.5 L DIESEL |
| TRANSMISSION | STT TYPE 8-SPEED AUTOMATIC GEARBOX |
| PAINT TYPE | PAINTED METALLIC EXT TRIM TYPE |
| BODY COLOUR | BLACK PEARL PAINT |
| INTERIOR TRIM TYPE | PREMIUM LEATHER UNIVERSAL TRIM C41 |
| UPHOLSTERY COLOUR | "FX" |
| GEARBOX (CHARACTERISTICS) | ATNG8 AUTOMATIC GEARBOX WITHOUT ELECTROMAGNETIC PUMP |
| CONVERSION GUIDANCE | WITHOUT CONVERSION |
| DEFINITION TO FOLLOW | INITIALE RANGE |
| ENGINE (TYPE) | DV TYPE ENGINE |
| OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
| Fuel Supply-Engine | |
| DRIVE BATTERY | WITHOUT TRACTION BATTERY |
| FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.4 ENGINE EMISSION CONTROL |
| EXHAUST | MUTE EXHAUST |
| CAPACITY | 1500 CM3 |
| CATALYTIC CONVERTER | WITHOUT CATALYST |
| FUEL TANK | NON-PRESSURISED FUEL TANK WITH LOCATING TAB |
| FUEL TANK INSULATION | WITHOUT FUEL TANK INSULATION |
| COOLING MOTOR | RADIATOR 21DM2 - EP21 |
| CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
| POWER VARIATION (ENGINE) | ENGINE POWER 96KW - 300NM |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.4 VEHICLE TECHNICAL EMISSION CONTROL |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 1E 2VTS 140W AERO SHORT NOZZLE |
| DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
| TANK FILTER | WITHOUT RESERVOIR FILTER |
| STOP AND START | WITH STOP AND START STARTER |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | FINAL DRIVE RATIO 15 X 58 |
| WHEEL STYLE | 18-INCH ALLOY C41 |
| RIM/TYRE SIZE | 18 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 195/60 R18 96H - NOT FOR DIFFICULT ROAD CONDITIONS |
| WHEELS FITTED | WHEEL 6.5J18ET27 |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| GEARBOX TYPE | ATN8 TYPE GEARBOX |
| Suspension-Steering-Brakes | |
| BRAKING ASSISTANCE IN REVERSE GEAR | WITHOUT REVERSE GEAR BRAKING ASSISTANCE |
| REAR ANTI-ROLL BAR | REAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD |
| ANTI-THEFT DEVICE | WITHOUT STEERING LOCK |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR DIAMETER 22 HOLLOW |
| BRAKES (CIRCUIT) | REAR DISC PROTECTOR |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| BRAKE ASSOCIATED VARIANT | CONTI MK100 ESP |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| AERIAL | REAR SPOILER AERIAL + DIGITAL + GPS + GSM |
| FINISHER (SELF-ADHESIVE) | GLOSS BLACK REAR SURROUND TRIM |
| SIDE MOULDINGS (TYPE) | SILVER GREY SIDE PROTECTORS |
| WHEEL EMBELLISHER (STYLE) | BLACK CENTRE CAPS+BLACK BOLTS DESIGN |
| EXHAUST TAILPIPE | CHROME PLATED EXHAUST TAIL PIPE |
| UNDERBODY SHIELD | FRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION |
| INDICATORS | LUMINOUS SIGNATURE |
| WASHER JET | WINDSHIELD WASHER JET WITH DEFROST |
| EXT. REARVIEW MIRROR COMP. FUNCTION | ELECTRIC FOLDING EXTERIOR MIRROR+DIODE |
| SPLASH SHIELD | ACOUSTIC FRONT + REAR MUD GUARDS + FRONT RIGHT-HAND EXTENSION |
| EXHAUST TAILPIPE TRIM | W/O EXHAUST OUTLET EMBELLISHER |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING UNDER BONNET + BULKHEAD + SERVO |
| WINDSCREEN GLASS (TYPE) | HEATED WINDSCREEN GLASS |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| BUMPER | BODY COLOUR BUMPER+GRAIN BLACK FRONT/GLOSS BLACK REAR SKIRT |
| FRONT FOGLAMP | LED FOG LAMPS + CORNERING LAMP |
| PANORAMIC VISUAL AID | VIDEO PARK 2 |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| EXTERIOR ACCESSORIES | BODY COLOUR EXTERIOR HANDLE |
| EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | WITHOUT EXTERIOR MIRROR SPECIAL FEATURE |
| SUN ROOF | SUNROOF SEQUENTIAL ASSISTED CONTROL + ANTI PINCH |
| BUMPER TRIM | SILVER GREY FOGLAMP TRIM |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED RR WINDOW GLASS |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS+BOOT+CONTACTLESS STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
| REAR SEAT | FX ONE-PIECE REAR SEAT+2/3-1/3 FOLDING SEAT BACK |
| BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
| REAR SEAT ARMREST | WITH REAR SEAT ARMREST |
| REAR SEATBELT | 3 PYRO RETRACTORD + SEATBELT FASTENED TELL-TALE |
| FRONT SEATBELT | REEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER |
| CLIMATE (AMBIENT TEMP) | COLD COUNTRIES |
| SPEED GRADUATIONS | SPEED GRADUATION IN KM/H |
| GEAR SELECTOR | GEAR SELECTOR AT THE FLOOR AND AT THE STEERING WHEEL |
| GRAB HANDLES | FRONT + REAR HANDLES |
| CONSOLE | UPPER TRIM |
| DRIVING POSITION | LEFT-HAND DRIVE |
| MIRROR LINK | WITH MIRROR LINK |
| LOAD SPACE LIGHTING | GLOVEBOX+LED FRONT CONSOLE |
| DASHBOARD EQUIPMENT | SLUSH GRAIN BLACK IDENTITY |
| INT. TRIM AND EQUIPMENT VARIATION | STANDARD INTERIOR EQUIPMENT DRESSING |
| MISC. INT. LAMPS | LESS INTERIOR LIGHT |
| INSTRUMENT PANEL (CHARACTERISTICS) | INSTRUMENT PANEL WITH MATRIX+WHITE AMBIANCE |
| DOOR TRIM | WITHOUT LINING |
| LOUDSPEAKER | 5 FR SPEAKERS+2 RR SPEAKERS+1 BASS BOX |
| POLLEN FILTER | WITH POLLEN FILTER + ACTIVATED CARBON |
| LANE KEEPING MANAGEMENT ASSISTANCE | LPA WITHOUT HIA DELEGATION |
| PASSENGER COMPARTMENT SOUNDPROOFING | SOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT |
| DRIVER SEAT ADJUSTMENT | DRIVER’S SEAT TILTING BACK ERGONOMIC ELECTRIC LUMBAR SUPPORT |
| FRONT PASSENGER SEAT ADJUSTMENT | ERGONOMIC ELECTRIC TILT BACK LUMBAR SUPPORT |
| FRONT SEAT ARMREST | FRONT CENTRAL ARMREST |
| FRONT SEAT ARMREST (OPERATION) | FRONT ARMREST MANUAL |
| SATELLITE NAVIGATION SYSTEM | CONNECTABLE NAVIGATION SYSTEM |
| HEADLAMP BULBS | ECO LED |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| TRAFFIC INFORMATION READER | LKA STRUCTURAL EDGE |
| DISPLAY | 10-INCH COLOUR HD TOUCH SCREEN |
| MISC. INT. ACCESSORY | PORTABLE SUPPORT |
| COURTESY MIRROR | DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING |
| OIL GAUGE | W/O OIL LEVEL INDICATOR |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | DRIVER + R1 PASSENGER HEATED SEAT |
| FRONT LATERAL AIRBAG | FRONT CHEST SIDE+REAR CHEST/HEAD CURTAIN AIRBAG |
| FOOTWELL LIGHTING | DRIVER + FR PASSENGER FOOTWELL LIGHTING |
| HEATING DUCT | FRONT+REAR PILLAR+REAR VENTILATION |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| WIFI | WITHOUT WIFI |
| STORAGE (DRIVING POSITION) | GLOVE BOX + DRAWER |
| RADIO RECEIVER | ANALOGUE + DAB RADIO RECEIVER |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | ACC3 DECEL0 + ACCEL0 |
| DRIVER’S SEAT HEIGHT CONTROL | DRIVER’S SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| STORAGE (OTHERS) | PLAIN STORAGE POCKET |
| CARPET COVER | WITH CARPETMAT |
| OBSTACLE DETECTION SYSTEM | FRONT/REAR/SIDE RADAR OBSTACLE DETECTOR + TRAJECTORY |
| TRIM ADAPTATION | WITHOUT MOULDING ADAPTATION |
| RADIO FREQUENCY | RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1 |
| LOCKING CONTROL | NORMAL + AUTOMATIC LOCKING |
| STEERING WHEEL | FULL FLOWER LEATHER ST WHEEL |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| AUDIO PACK AUXILIARY SOCKET | AUDIO PACK AUXILIARY SOCKET 1 USB TYPE C |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ALTERNATOR CLASS 18 HEA |
| BATTERY | L3 760 70AH EFBC 760 BATTERY BECOMES EFBC |
| STARTER MOTOR | STTD STARTER |
| CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
| BATTERY CHARGER | WITHOUT ON-BOARD CHARGER |
| MULTIPLEXING | R3 ECO ELECTRICAL ARCHITECTURE |
| ELECTRIC VEHICLE CHARGING PLUG | WITHOUT VEHICLE LOAD RECOGNITION |
| BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| MODIF. DURING MODEL YEAR | WITHOUT MINOR MODIFICATIONS |
| CONDENSER (SPECIFICATIONS) | CONDENSER 20DM2 - THICKNESS 12 CLASS 2 |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| LABEL | WITHOUT LABEL |
| AIR CONDITIONING PIPES | STANDARD AIR CONDITIONING PIPES |
| TRAFFIC SIDE | DRIVING ON THE RIGHT-HAND SIDE |
| SET OF KEYS | SET OF BADGE KEYS + BACK-UP KEY |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
| SURFACE CONDITIONS | GOOD TERRAIN |
| SPEED MONITORING | WITHOUT SPEED CHECK |
| SLAVE CONTROL UNIT | BSI + COM 2020 |
the2ems
- x 10
Update on the auto lock/alarm activation. I’ve just been to the dealer on an unrelated issue, but whilst there I mentioned about the alarm going off when I left my wife sitting in the car, while I went into a shop with the keys. Now the owners manual states that “The alarm does not activate when locking automatically from a distance” But mine does. The person I spoke to went to talk to the service manager, who apparently has the same model as me, and his does the same.
CITROEN C4 1.2 PURETECH C-SERIES EDITION S/S 5DR (2023)
- x 6950
Personally I think it's a bit of a daft idea to be honest, as logically I would want it to lock and arm the alarm if this is the intention, otherwise what's the point if you have to unlock it and re-lock it after auto locking to arm the alarm that way?
Accepted that it is not ideal if you are leaving a passenger or animal in the car for short periods and it locks on walking away. I suppose you'd have to deactivate the volumetric protection before you did, so it doesn't set of the sensors from inside movement.
Perhaps you should just get the auto locking deactivated by the dealer whilst there and be done with it, relying on the fob to lock / arm and unlock/ disarm?
the2ems
- x 10
Is that something they can do?GiveMeABreak wrote: 23 Oct 2024, 15:18
- x 6950
They may well be able to, as they can disable the hands-free element of most of their vehicles, so a possibility you may want to ask about.
the2ems
- x 10
I’ll certainly bear it in mind.GiveMeABreak wrote: 23 Oct 2024, 17:25 They may well be able to, as they can disable the hands-free element of most of their vehicles, so a possibility you may want to ask about.
