Citroen c3 picasso
Huskyxantia
x 906
Re: Citroen c3 picasso
Unread post by Huskyxantia »
myglaren wrote: 15 Dec 2023, 11:55 I have been meaning to chuck my locking nuts away and replace them. No need now but definitely with the next car. Nothing but a nuisance.
To be honest there's so many cars now with alloy wheels are they really needed , back when the old escort xr3is were having there's stolen they were needed then but didn't really stop the crooks ,they are a nuisance when they wear & expensive to remove if you needed someone to do it its about 100 quid a wheel where i am. Only takes 30 seconds ! If you can move yours and replace them i defo would while you can
:-D
x 8385
Huskyxantia wrote: 15 Dec 2023, 16:34
mickthemaverick wrote: 15 Dec 2023, 16:30 Excellent - service with a smile Well done Husky!! :-D
Thanks Mick, made my spirits lift i can tell you. Im sure my late father is watching over me, hope he is, miss him like mad.
That's absolutely magical Husky, I have a massive smile on my face right now :-D And yes your dad is just like mine is... Like you, it's been 7 years now and I still miss mine like mad...
x 1487
Go into engine ECU then STD parameter measurements, and look for oil pressure. I'd have thought you'd be looking around 3 bar idle and maybe 4-5 at 3000 rpm.
Huskyxantia
x 906
RichardW wrote: 15 Dec 2023, 17:36 Go into engine ECU then STD parameter measurements, and look for oil pressure. I'd have thought you'd be looking around 3 bar idle and maybe 4-5 at 3000 rpm.
Brilliant , will be having a look hopefully tomprrow! Post my findings tomorrow. Cheers Richard.
:-D
Huskyxantia
x 906
CitroJim wrote: 15 Dec 2023, 16:53
Thanks Jim, i was with him just a few hours before he passed, he comes back in my dreams , that old saying you don't know what you got till its gone is so very true. He used to follow my car stuff , only by asking me each week i used to vist him always interested in what i was doing. I feel I'm slowly getting some where with this little Picasso , only drove it twice carefully mind you it feels so nice .
:-D
Huskyxantia
x 906
I'm off now my spellings getting bad ! More to come tomorrow
:-D
x 1487
At a loose end, so I checked my 3008 with the same DV6C engine...it just says oil pressure OK, no figure given. Would need to see a wiring diagram to understand if there's more than one set of contacts that might give a high reading.
x 1068
Unread post by Rp0thejester »
I can't believe people still use locking nuts, what a faff they are! I had mine round off so got a friend to weld a bolt onto them, worked like a charm.
Huskyxantia
x 906
RichardW wrote: 15 Dec 2023, 20:27 At a loose end, so I checked my 3008 with the same DV6C engine...it just says oil pressure OK, no figure given. Would need to see a wiring diagram to understand if there's more than one set of contacts that might give a high reading.
Good point i was wondering if the oil presser sensor switch might be on its way out , or gunked up. Maybe someone could be so kind and pop a wire diagram up?
:-D
Huskyxantia
x 906
Rp0thejester wrote: 16 Dec 2023, 06:21 I can't believe people still use locking nuts, what a faff they are! I had mine round off so got a friend to weld a bolt onto them, worked like a charm.
That's why i don't use or want them there off mine now thank god. For me the design is just to weak plus the mechanic with his rattle gun don't help either as by my photo these bolts should be labeled unfit for purpose
:-D
Huskyxantia
x 906
:-D
x 8385
That's exceedingly valuable for many reasons :) Thanks for popping that up Husky :D
x 8385
Huskyxantia wrote: 16 Dec 2023, 09:20
Could have sworn mine gave a figure... In that case I too am curious to know how it knows it's too high!
x 1068
It's like a blood pressure machine, only a fully qualified info maniac will be able to decipher it
Huskyxantia
x 906
CitroJim wrote: 16 Dec 2023, 11:59
Mine too will display on the dash oil ok when the ignition gets switched on so it knows the level is where it should be, that's a plus for me .More news my pick up pipe has arrived today . Oil feed, oil strainer pipe so many names for one part, new bolts and gasket too.
:-D
