C5 2012 - P0928 Error
x 6957
Re: C5 2012 - P0928 Error
This fault appears because the Gearbox control ECU software no longer activates the shift lock and appears when using the diagnostic tool.
The fix is:
  • Exit the diagnostic session.
  • Switch on the ignition positive.
  • Switch off the ignition for 50 seconds.
  • Resume a diagnostic session without switching off the ignition.
  • Erase the fault codes.
bahcekapili
x 9
Unread post by bahcekapili »
I did and it worked. Thank you so much.
x 6957
