1.6 e-hdi camshaft position sensor
c16rkc
x 104
Re: 1.6 e-hdi camshaft position sensor
Unread post by c16rkc »
wheeler wrote: 30 Sep 2023, 19:55 Unfortunately i have found the DV6/5 engines not as forgiving after a timing belt failure. The cam lobes are pressed on to the shaft & they often twist on the shaft. Seen plenty of them damage valves too. On the older DW10 8v engines i have never seen a single one damage a valve after a timing belt failure.
Is my engine in the C3 a DV5/6 then?
x 1067
Unread post by Rp0thejester »
I find that taxi companies use Mercs etc as there prestigious cars. Citroens are designed for comfort, like a 2CV with eggs on the bonnet, it's designed for comfort, if Citroen ever changed that I'd be looking at other cars!!
x 6956
c16rkc wrote: 30 Sep 2023, 19:57
DV6TED
