Thanks for getting back to me,
my vin is,
VF3**************[VIN obfuscated, can be read by forum staff],
Someone new has scanned the car and has gave me three codes,
P3057
P2200
U1000
Currently unsure what to do with the car do I bite the bullet and put it into a Peugeot dealer or an auto electrician?
Seen a few people have handed cars back to Peugeot under advice from citizens advice Scotland as the cars were under 3 years old and under warranty, they are saying the car is not fit for purpose with various faults,
Thanks again
ESP/ABS warning... C1391... C003A Right rear speed sensor
Martino07
- x 6945
Re: ESP/ABS warning... C1391... C003A Right rear speed sensor
Unfortunately that's a bit late for you to do now...
I don't have exact descriptors for the other faults but the U1000 is a data / comms fault and that can vary depending on the system.
A Peugeot dealership diagnostic will be a minimum of £120, but may work out better in the long run rather than 'taking it here and there on wing and a prayer' as Peugeot will also have the expertise and the technical resources for troubleshooting.
| Fault Code: | P3057 00 |
| Description of Fault: | Particle filter: Estimated number of particles incorrect. Estimate of the number of particles accumulated incorrect. |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
Fabrob
- New User
Thanks for the ESP schematic Givem3abreak, looks like it will be very useful. Don't suppose you would happen to have the legend for the schematic you legend
- x 6945
Remember, schematics are both vehicle, engine and option specific, so may may not be relevant to your own vehicle. In order to see if I have one relevant to your own vehicle, you'll have to provide a VIN.
The link to the main equipment codes is back in the post with the diagram (I've just updated it).
SHattie
Morning all, would appreciate any help on this matter. My 2019 Citroen Berlingo (K9) is throwing up all sorts of warning lights and codes. The main code is C003A 11.
Rear right speed sensor, Short circuit to earth. However I have changed the abs and speed sensor. Replaced the short wiring loom to the sensor and calliper. And still has not been resolved. Only next this is to do the bearing itself but if that fails I’m not sure where to look next. Any experience on this would be greatly appreciated.
PaulC5
- x 692
What are the other codes since they may be relevant to have a look at ?
At the rear right there will be 2 sensors, the outer and the inner so have you checked both of these ? These 2 sensors might also have different part numbers so it could be important when replacing to get the correct one.
5/5/2026 edit - ignore the bit about 2 sensors, for some reason I was thinking about reversing sensors.
SHattie
This is all the codes showing currently
C003A:01 - Rear Right Speed Sensor - Electrical Fault
C003A:11 - Rear Right Speed Sensor - Short Circuit to Earth
C003A:96 - Rear Right Speed Sensor - Internal Fault
U1213 - Communication fault between the electric power steering (dae) ecu and the abs/especu-Not characterised
And yes we checked both inner and outer sensors, same part no’s replaced and only thing left is the bearing itself which is being done this coming Thursday now.
There is also all the ESP/ABS/Hill start fault coming on the dash at start up too.
PaulC5
- x 692
Just realised, for some reason I was thinking about reversing sensors so my above post should be ignored. It may pay to check the wiring from the front of the car to the back and look for any damage.
