Problem with fuel pump, Xantia won't start.
x 1057
Re: Problem with fuel pump, Xantia won't start.
Unread post by wheeler »
DS-Reval wrote: 12 Nov 2025, 12:15 MM01 seems good also, but what is wire 822 (A&B) supposed to do ? It seems to be able to influence operation of the relay also. Pin 3 of the relay and pin 34 on the ECU should be connected, the connection is not very stable on my car though. And what is 82-- on the scheme 12.6 ? That is supposedly where 822 A and 822 B should meet ?
Looks like 822 joins inside the double relay to CC2B which is an ignition controlled live feed.
82-- is the immo system so some will be comms wires to the CPH.
CPH failures i would say are very rare.
