Citroen parts
x 6947
Re: Citroen parts
Ok, so I've done a bit of searching and located one in Sweden:
https://en.bildelsbasen.se/?index=defau ... ery=6490Y4
I have checked the VIN this came off of and it is the exact part number '6490Y4', so it's a perfect match for your unit. it costs 496 SEK which is about £41. There will be some shipping costs, so may be worth contacting them.
More details on the part here:
https://en.bildelsbasen.se/?index=defau ... d=21812304
Estate87
(Donor 2021)
Re: Citroen parts
Unread post by Estate87 »
GiveMeABreak wrote: 31 Mar 2021, 11:27 The difficulty you will have is identifying the correct part - as the number I have provided is an internal PSA part number used by Citroen / Peugeot /DS. These are often not printed on the electronic component / module, so although they can look the same across model physically, they are quite different electronically, hence why there were 15+ different variants. It would of been a lot easier if you had the original part so you could of looked for some internal reference numbers and used these to help in your search for a direct replacement. But best of luck in finding one.
Perhaps I'll have a rummage around in the skip at work to see if I can find it again.🤞🏻
Cheers
Estate87
(Donor 2021)
Re: Citroen parts
GiveMeABreak wrote: 31 Mar 2021, 11:34 Ok, so I've done a bit of searching and located one in Sweden:
Top man Marc thank you very much I'll have a look at that now. 👍🏻
Cheers
Estate87
(Donor 2021)
Re: Citroen parts
Will it matter too much that it's from a Swedish car? It doesn't matter whether the car is left or right hand drive? Probably a stupid question.
Cheers
Estate87
(Donor 2021)
Re: Citroen parts
I've enquired about that part. Couldn't get my head around the buying process though?
Cheers
x 3296
Re: Citroen parts
So long as the part number is a match (and where Marc is concerned it WILL be a match) it will work properly. Most intelligent designers will avoid duplication of their work, and why would you want two designs of control module (one for a left door, the other for a right door) when you can simply have one design for either door (and it saves money producing one module as opposed to two)?
Estate87
(Donor 2021)
Re: Citroen parts
Hell Razor5543 wrote: 31 Mar 2021, 16:49 So long as the part number is a match (and where Marc is concerned it WILL be a match) it will work properly. Most intelligent designers will avoid duplication of their work, and why would you want two designs of control module (one for a left door, the other for a right door) when you can simply have one design for either door (and it saves money producing one module as opposed to two)?
Very good point.
Cheers
x 6947
Re: Citroen parts
Estate87 wrote: 31 Mar 2021, 16:47
Cheers
They're like a parts gateway for various sellers.
The switch is actually with the seller:
https://haggsbildem.se/en/contact-us/
They have an English page too - use the parts info from the links I put up in the last post (Stock Number W273606 & PSA Part Number: 6490Y4) and post this link in the email: https://en.bildelsbasen.se/24-W273606.html and use one of the contact emails shown on the link above. See how you go.
Estate87
(Donor 2021)
Re: Citroen parts
GiveMeABreak wrote: 31 Mar 2021, 17:07
Cheers
I've sent them an email. 🤞🏻
Cheers
x 6947
Re: Citroen parts
Ok, fingers crossed you get a reply.
Estate87
(Donor 2021)
Re: Citroen parts
GiveMeABreak wrote: 31 Mar 2021, 19:05 Ok, fingers crossed you get a reply.
Received the part today from Sweden. It's in brilliant condition, haven't tested it yet but just wanted to say thanks for your help in locating it mate.
Cheers
x 6947
Re: Citroen parts
No worries, I hope this does the business.
