Citroen C5 2.0HDI 2016BlueHDI 150 Engine Repair light
x 6957
Re: Citroen C5 2.0HDI 2016BlueHDI 150 Engine Repair light
Hi Tony - they won't update it if it is not relevant to the specific engine ECU in your C5 - or does not require it. These types of updates are not issued as ongoing software updates (like the never ending Windows updates :roll: ). They can check to see if there is one as I mentioned, but they can actually cause issues if they are applied unnecessarily - as other components / software may also need updating - which they may not be able to be,- depending on hardware and software versions. They are quite tightly managed for this reason and won't apply an update (if indeed there is one) for this reason unless it is required.
I've seen cases, myself included, where a BSI update has had a knock-on effect to other systems.
But going back to that specific fault, it can be the condition of the oil:-
It's more to do with the particle filter. It's the regeneration element that causes the issues where the engine oil gets diluted by the diesel fuel. A resonant sensor system for determination of diesel content by measuring the viscosity of the oil can be used - and this is the issue being referenced by the fault as far as I can see.
Diesel fuel that contains the particle filter additive floods the cylinders - and gets past the piston rings into the engine sump. So where this is detected as being too diluted - it can flag the fault code and that is why one of the remedies is to change the engine oil.
tony42
x 4
Unread post by tony42 »
Hi Marc, Thanks noted, I remember when I originally got the C4 I am discussing in the other thread there was a problem with the car. Long story short an attempt theft by slicing passenger door cable with a stanley knife or something. I had to get the wiring loom replaced for that door. Had to go to a main dealer because the local garage couldn't get all the functions working. Main dealer found there was a fuse blown that impacted some functions! Anyway I asked since they had it on their machine was there any updates and his answer was similar to what you outlined re updates causing more problems potentially.
Going back to the specific fault Will see what happens here over time I am hoping that there is no real issue. I would have thought if the oil is contaminated and if there is a sensor surely it would re-alarm if the oil was not changed? I change the oil once a year anyhow and my mileage is low and lower because of covid so change will happen with probably max of 8-9k miles done.
