C?TROEN C5 2011 SX PK 2.0 HD? 163
sonerpc
Re: C?TROEN C5 2011 SX PK 2.0 HD? 163
Unread post by sonerpc »
GiveMeABreak wrote: 08 Apr 2019, 11:57 Please note that on the DW10C engine, the by-pass function is not active, the hot air (by-pass) flap is only activated in the event that the cold air (mixer) flap seizes.
So although you have the double air doser, the left hand plug is purposefully disconnected (the wiring plug will be hidden) and there should be no vacuum pipe attached either. So DO NOT connect this up, as it is designed to be left off!
I share your information with the mechanic.
Thank you very much for your labor.would you mind if I use my car.
Is it so difficult to make a fault detection?why are they so ignorant.
I think they never research
sonerpc
elektro valfi=elektrovana ?
if the breakdown of this piece is not over 3000 cycles.
if this is the right information my tool is going smoothly
sonerpc
new error code...
It was a mistake to take a car in 250 thousand.and it was a mistake to get from the dealers.
now code p2562 and p1497...
I have filed a corrections, but irresponsible
x 6950
Here are the fault code descriptors for you:
Fault codeP2562
After sales description of the fault codeVariable geometry turbocharger: Position incorrect in relation to the requirement
Not enough turbocharging
Description of the diagnosticsThe position measured is greater than the reference by more than 40 % for 6 seconds
Conditions of activation of the diagnosticsengine running
Conditions of disappearance of the faultDriving with the engine hot for 5 minutes
Down-grade modes if fault presentDeactivation of the EGR function
Switching on of the warning lamp and/or warning messageWarning lamp MIL
Main customer complaints likelyNoise
Smoke from the exhaust
Lack of power
Loss of braking
Suspect areasTurbocharger: Variable geometry open
Turbocharger solenoid valve
Position indicator of the turbocharger
Electrical harness
Vacuum circuit
Fault codeP1497
After sales description of the fault codeVariable geometry turbocharger: Position incorrect in relation to the requirement - Not enough turbocharging
Description of the diagnosticsThe position measured is greater than the reference by more than 30 % for 6 seconds
Conditions of activation of the diagnosticsEngine has been running for at least 6 s
Down-grade modes if fault present-
Switching on of the warning lamp and/or warning message-
Lack of power
Loss of braking
Turbocharger solenoid valve: Failure of the solenoid valve
Electrical harness
Position indicator of the turbocharger: Electrical harness
Vacuum circuit leak
sonerpc
You're trying to help everyone.they are manufacturer error information and valuable information.my car has 4 faults and electric circuit and vacuum circuit.should I show a good electrician?or I should take my authorized service directly.
x 6950
All this seems to be pointing to the vacuum circuit. A mechanic should be able to check the vacuum circuit or the solenoid valves to see if they are operating properly. Start with the easier things like checks.
If you don't have an experienced mechanic who knows PSA cars, and you don't do your own mechanics, then it might pay to take it to the authorised service centre who are trained on the cars and should be able to run the checks for you. They will do a diagnostic to confirm these codes and do the checks for you. But they should give you an estimate before they complete the work.
sonerpc
mechanic have very close buddy.but he is scared and inadequate on citroen :)do you have any idea how to control the vacuum circuit.
turbo solenoid valve in the motor picture.Can we check the robustness of the turbo solenoid valve.
sonerpc
sonerpc
hello GiveMeABreak.we need to change the gearbox oil.which oil should we use and need a picture for removal.
feel proplem in gears.özellike 4-5 5-6 between.manuele gear does not seem to take trouble.
oil can be old
x 6950
You have the AM6 Auto box. You cannot change all the oil in one go - the capacity is 7 litres and you can only remove 3 litres at one time! So you may need to do several oil changes over a few months to get most of it replaced.
The official guidance for changing the Oil is here:
viewtopic.php?f=3&t=58731&hilit=Refit+t ... 15#p553039
Note: You will need to reset the oil counter in the ECU as part of this operation. You will need Diagbox or a compatible tool to do this.
EDC5 has done a guide to changing here:
viewtopic.php?t=58134&start=45#p542882
justkior
New User
Unread post by justkior »
GiveMeABreak wrote: 21 Mar 2019, 20:04 The U1218 fault can relate to an intersystems CAN fault in relation to the STOP Start system if you have this fitted.
First post your VIN up here so I can identify your vehicle.
Hi Marc,
Hopefully you can help me. I have U1218 fault in my car (Peugeot 3008, 1.6 hdi) and the fault shows up on my dashboard when Stop/Stard deactivates. It all happens automatically. Even I press Eco button it doesn't do anything.
Do you have any suggestions what could be the reason? I think the fault is related to car's Start/Stop system. I just don't understand what could be the reason.
The battery seems to be OK.
Dinu
x 6950
Dinu- pop your VIN up for me and any other fault codes you are getting and I’ll check it against your vehicle.
jackeldestripador
Unread post by jackeldestripador »
hi friend i have the same fault U1218 in some citroen c3 vin: VF7**************[VIN obfuscated, can be read by forum staff]. Fault present in BSI either abs has comm faults and ecu.
Thanks!
