Coolant temp vs Oil temp
vborovic
Locked user account
x 40
Re: Coolant temp vs Oil temp
Unread post by vborovic »
Paul-R wrote:You cannot be sure that the scale is linear, logarithmic or the profile of my nose!
You can be sure, but I don't want to argue here about it ... whoever has the means (Lexia/DiagBox), can confirm the linearity of the visual representation and the actual values returned for themselves ... or live in misinformation ... I chose the first one for myself ... :D
x 1746
jgra1 wrote:..a green thing. It has no temp gauge of any sort! It's actually bliss not knowing anything ;)
Remember the Morris 1000 and the basic Mini: Speedo, fuel gauge, and three indicator lights (IGN, oil pressure, turn).
Renault Twingo (sadly never available in RHD) revived that, with its one huge digital speedo display. Lovely.
Do like the classic British dash though - full set of circular dials, white on black, as per Rover, Jaguar, Triumph, MG, Bristol and even the S2 XM. Jaeger produced some great instrumentation.
BenC5HDi
Not Mike
x 45
Re: RE: Re: Coolant temp vs Oil temp
Unread post by BenC5HDi »
My C1 is much the same. One big round dial with the fuel gauge and a few warning lights inside it. Brilliantly simple.
x 1938
Unread post by Paul-R »
Maybe those of us with Lexia/Diagbox capabilities. But for the man in the street? As was pointed out earlier it's all part of the dumbing down of information. As I said you have to trust the designer of the instruments that the reading actually has a proper meaning.
x 1489
I would have expected it to be driven to the middle for 'normal' temperature, that's what drivers expect / want to see. I'd be checking the actual temp with Lexia, and working on the assumption it needs a new stat....
ohyes
Unread post by ohyes »
Too bad I don't have a friend nearby who could run some diagnostics as I would need to go to the local dealer/service for a check
elma
x 284
Unread post by elma »
I have to have a gauge, family have had a couple of cars without one. They all had an overheat warning light but no underheat light to indicate such things as a worn thermostat. There probably isn't a need for oil temp but I keep an eye on it and in hilly North Wales sometimes it gives me good reason to slow down a bit up the hills. I like gauges though, I'd add oil pressure, turbo pressure and maybe some others quite fast if they wouldn't ruin the standard look of the car.
x 1995
Unread post by Stickyfinger »
Our old Slurry Skipping Kia has no gauge, it does have a blue light/no light/red light system. It restricts revs until the blue goes out.
elma
x 284
Blue light sounds good, thats my major gripe with gaugeless cars, even the Astons only had an overheat light when they went gauge less for a while.
x 1746
With LCD screens now pretty much standard, why not Full AndroDiags? \:D/
x 5672
May be comparing apples and oranges but on my analogue gauges the water temperature rises fairly quickly but the oil lags quite noticeably.
I had to check this morning as it is rather seldom that I look at them, same with the oil gauge. Just keep fingers crossed mainly.
x 3296
I find that on my C5 the coolant gets warm way before the oil temperature starts to move.
elma
x 284
My Xantias the same with coolant warming over a few minutes and oil taking over 10 usually.
ohyes
So you guys think this may be a problem? I should check it in the service I guess then :(
x 3296
I would not say it is a problem. On my C5 the coolant warms up faster, but when things stabilise they are both around the same temperature (depending on my driving). Remember, due to the cooling fans the coolant temperature can change faster and through a wider range then the oil temperature.
