Just bought a 307
Gibbo_Wirral
Re: Just bought a 307
Unread post by Gibbo_Wirral »
Just replace it, they're not too dear:
http://www.cats2u.co.uk/" onclick="window.open(this.href);return false;
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
doctle
x 225
Unread post by doctle »
Gibbo_Wirral wrote:Just replace it, they're not too dear:
Thank you, theyre surprisingly affordable :)
Oh buggle
doctle
x 225
Progress
I went to do a bit more cleaning today, I just learned how to move the slam panel to remove the cat heat shield. The shield is in poor condition so I took it off then took off the cat. There was a loose ball of ceramic stuff inside so I broke it up and removed it. Refitted the cat and the car drives very well. I think the oil is coming from the oil cooler or the filter housing. I ordered an EGR blanking plate in case the valve was sticking so thats next when it arrives. Anyway thanks to all you guys for your input. I need new heat shields, are they expensive new?
Oh buggle
Gibbo_Wirral
Re: Progress
doctle wrote:I need new heat shields, are they expensive new?
Assuming its part 1723 R0, and depending on which RPO number its a reasonable £24.19.
Servicebox will give the exact parts if your VIN is put in.
doctle
x 225
Re: Progress
Thank you, I registered with service box then rang my Peugeot dealer with the part numbers. €60.00 bolts and clips extra. Dang
Oh buggle
BX
x 19
Unread post by BX »
Price them with a Citroën dealer. They are often substantially cheaper. There is also Ford and Mazda. Can you not repair and refit the shields using a little light aluminium? Anyway I would be inclined to sort the oil leaks before even thinking about the heat shields.
Gibbo_Wirral
Also put the part numbers into Ebay. I've bought genuine parts from Peugeot dealers in various European countries via Ebay for cheaper than their UK counterparts.
doctle
x 225
Gibbo_Wirral wrote:Also put the part numbers into Ebay. I've bought genuine parts from Peugeot dealers in various European countries via Ebay for cheaper than their UK counterparts.
Thanks for the tip :)
Oh buggle
