headlights
AndersDK
BonceChops
It is about time the 'legal' measurement of a lamp was in lumens and not watts. Why should us halogen lamp users be stuck at 55w when bmw merc etc are using discharge lamps several times brighter. Surely the whole idea of limiting the brightness of lamps is to avoid blinding other road users. So why measure this brightness in watts? Just another example of outdated law or the knowledge/intelligence of the people who set the law.
Kowalski
RichG
A little while ago I fitted some Osram Silver Star bulbs to my '98 pre-facelift Xantia. After reading this thread I decided today to check the beam alignment.
Using a laser level to check the level of my drivway and find the centre of the car I marked the correct position of the beams (1.2% Down) on my garage wall.
Whilst I could alter the up/down position by using the inner of the two adjusters each side I could not alter the horizontal positon of the 'kick' point which appeared to be too far to the right. Each outer adjuster only seemed to rotate the beam and not move it to the left. Is this correct?
Richard
Richard
rabenson
I don't think that you can use discharge bulbs as main beam. They take a few seconds to reach full brightness. The kits that I've seen that enable you to replace a dual filament bulb work by manually shifting the single discharge lamp to change the beam pattern. A friend of mine with an audi had a discharge lamp fail and it took the balast with it - total repair cost £350.00! I'll stick with my vision plusses.....
BonceChops
