radius arm/bearings??
x 1488
Re: radius arm/bearings??
RichardW wrote:There must be a connection on the ABS sensor
According to haynes it's on top of the fuel tank accessed via the fuel pump / filter access port under the rear seats. Also suggests that you might need to drop the tank a bit to get at it :x Paul might remember as he fitted a replacement arm....?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
A look at the Fleabay sensors for sale shows the massive cable length!
deano1970
Unread post by deano1970 »
well,the car has cost me a bit recently.........£ 327 on the radius replacement kits and fitting plus 70 for a new battery.........put it in for mot yesterday and...............wahey, passed needing just a side light bulb........not sure why they issue a refusal for an mot due to the bulb, then replace it and print out a pass sheet? dunno but happy to say it passed easily, and the emissions were spot on.....guess that's down to very regular servicing...anyway, happy now,car mot'd till jan 15 :-D
C5 X7
x 94
Unread post by citronut »
deano1970 wrote: not sure why they issue a refusal for an mot due to the bulb, then replace it and print out a pass sheet?
because they are not allowed to do any repairs in the MOT test, so it has to be put down as a fail,
this is the reason MOT's were computerised!!!!, to save trees :? :? #-o :roll: :wink:
Regards, malcolm.
deano1970
ha, nice one malcolm.....seems silly doesn't it?? it's fine i guess if there is a lot of work needed but issuing a refusal seems petty and as you say, a waste of paper....ended up with three pages stapled together if you include the emissions pass sheet......still, glad it's passed.......I did put pics of my C5 on here, I wonder, as the passenger side has some dents, will one of these dent pullers pull them out? there isn't any broken paint??
C5 X7
Lighty
x 34
Unread post by Lighty »
Only just picked up on this thread, and noticed that you are not far from me, might be worth a mental note in case you have more issues. To be fair, you got a good price for the arm bearings.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
