Death of another Activa now double trouble
- x 8422
Re: Death of another Activa
I’m sure he'll have no problem at all with it. The rear ram is a lot easier than the front to do...
holmedog
- x 5
It appears to be the leakoff pipe that is leaking so is it a case of just replacing that or do I do the whole ram off replace the collar, as explained on your web site.
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
- x 8422
That's the usual problem. The rubber spigot from the collar will be split and perished where the leakoff pipe joins.
Yes, it's a classic case for the collar repair...
holmedog
- x 5
Thanks jim, that's what I was afraid of need to sort that a.s.a.p.
DHallworth
- x 161
If the car has been sitting for a while, try using it and putting up with the leak for a bit.
Mine always leaks in the Spring when I pull her out of the garage but when it warms up a little she settles in really nicely and stays dry.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 8422
Exactly the same with mine David...DHallworth wrote: Mine always leaks in the Spring when I pull her out of the garage but when it warms up a little she settles in really nicely and stays dry.
holmedog
- x 5
O.k will try it hope my dodgy m.o.t. Man can pass it with that leak.
- x 8422
Depends on how bug the leak is... If it drips it's a fail. if it's damp (weepy) but not dripping it should pass. Wipe it thoroughly just before the test...
holmedog
- x 5
Should pass all my mate will most likely say is sort it a.s.a.p.
- x 8422
holmedog
- x 5
- x 8422
Hinges do have some range of adjustment but also the rubber bump stops on the slam panel are adjustable. Pop the rubber ends off and you'll find a bolt and locknut underneath...
The bonnet must close properly for the MOT.
holmedog
- x 5
Thanks for that jim. As usual you are the font of all knowledge.
holmedog
- x 5
- x 8422
I'm sure we can work something out with the ram
I've done one at a rally before now...
