Death of another Activa now double trouble
x 8352
Re: Death of another Activa
I’m sure he'll have no problem at all with it. The rear ram is a lot easier than the front to do...
holmedog
x 5
Unread post by holmedog »
It appears to be the leakoff pipe that is leaking so is it a case of just replacing that or do I do the whole ram off replace the collar, as explained on your web site.
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
x 8352
That's the usual problem. The rubber spigot from the collar will be split and perished where the leakoff pipe joins.
Yes, it's a classic case for the collar repair...
holmedog
x 5
Thanks jim, that's what I was afraid of need to sort that a.s.a.p.
DHallworth
x 166
Unread post by DHallworth »
If the car has been sitting for a while, try using it and putting up with the leak for a bit.
Mine always leaks in the Spring when I pull her out of the garage but when it warms up a little she settles in really nicely and stays dry.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8352
DHallworth wrote: Mine always leaks in the Spring when I pull her out of the garage but when it warms up a little she settles in really nicely and stays dry.
Exactly the same with mine David...
holmedog
x 5
O.k will try it hope my dodgy m.o.t. Man can pass it with that leak.
x 8352
Depends on how bug the leak is... If it drips it's a fail. if it's damp (weepy) but not dripping it should pass. Wipe it thoroughly just before the test... :wink:
holmedog
x 5
Should pass all my mate will most likely say is sort it a.s.a.p.
x 8352
Fingers crossed it does Holmdog [-o<
holmedog
x 5
:? The only other thing i can see wrong is the bonnet will not close properly. Is there normally room for adjustment on the hinges. David said he thought it was sprained but it all looks straight and seems to line up perfect when pushed down into place. :? :P
x 8352
Hinges do have some range of adjustment but also the rubber bump stops on the slam panel are adjustable. Pop the rubber ends off and you'll find a bolt and locknut underneath...
The bonnet must close properly for the MOT.
holmedog
x 5
Thanks for that jim. As usual you are the font of all knowledge.
holmedog
x 5
:-D Bonnet all sorted. Got some part worn tyres on the vsx set of spare alloys. Tha Activa alloys will get a refurb on new tyres in the summer i think. Ready to go to the m.o.t man. The leak seems to have subsided. It was stood for 2 years round at dr.madvibe's place. If it does re-occur i will have to book it in at the garage of jim,if he doesn't mind. It would be great to meet the man who has been such a help not only with this Activa but also my old one. 8-) :-D :-D 8-)
x 8352
I'm sure we can work something out with the ram :wink:
I've done one at a rally before now...
