Another Lemming Jumps Off The cliff...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I've cryptically referred back to my car's thirst on .co.uk, however I'll expand a little here.
Found an almightly vacuum leak where the depollution electrovalve had busted in two, allowing a 3/8" ID line to feed air into the throttle body. Clamped the line shut and instantly, better brakes off a cold start, better economy by 20% and slightly better response off the pedal.
Expect the CAS and plug lead issues will sort out even more foibles.
x 8442
Re: Another Lemming Jumps Off The cliff...
Great news you've found the cause of the high consumption Adam :D :D :D
Not such good news on the original topic of this thread. The repair did not last and the epoxy was found gooey and not doing its job..
I tried another repair attempt but with the same result and have reached a conclusion that anti-freeze and heat attacks it over time...
So, I've bitten the bullet and have a new rad on order... Even if I tried another repair attempt I'd not be able to trust it so a new one is the only answer...
Hopefully the bottom bayonet will not be a problem this time...
Citroenmad
x 110
Unread post by Citroenmad »
Have you gone for another Valeo rad Jim or have you changed brands due to the problem with yours?
Ive still not fitted my Valeo one ...
I guess your looking forward to doing the job again :^o
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
robert_e_smart
x 14
Unread post by robert_e_smart »
What did you use out of interest?
Chemical Metal is good stuff.
1990 XM 2.1 Turbo SD
1991 BX 16 TGS Auto
1992 ZX 1.6 Aura Auto
1994 Xantia 2.0 16V VSX
2008 C5 2.7 Exclusive
Chris570
x 36
Unread post by Chris570 »
you know who to call if it is ;)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
