lumpy start and white smoke 1.9 td
Synergietom
MikeT
- x 232
Hi Tom, you can leave the leak-offs, I guess you best decide which offends least - replacing the leak-off's or the clouds of smoke - not saying it'll fix it mind.
I'm not sure how your engine management is configured - is it electronic? Possibilities can be boost leak (if turbo'd), overfuelling, timing, intake or exhaust blockage.
MikeT
- x 232
Is it "...black smoke at higher revs", or should it be "at higher revs it's fine"?Synergietom wrote:Mike any ideas on what could be causing the Black smoke at higher revs its fine untill you hit 30 ish in lower gears then it gives out a small cloud of distinct black smoke and it does this moreso when its cold.
Synergietom
sorry mike yes its Black smoke at higher revs.
Ive recently had the timing belt changed allong with the water pump which i had to pay a mobile mechanic for as i couldnt get the bottom pully off.
This was only changed as the timing had slipped a tooth.
He did a great job and was pretty cheap at £50.
I have noticed over the past couple of weks that it keeps losing a little power but not for long sometimes its a little slugish in 3rd when trying to pick up a bit of speed and othertimes its fine allthough being such a big thing its never really been very quick but saying that ive not had it long and being my first citroen who knows which of the problems ive allready fixed where allready there and which ones have appeared since i bought it.
I think the engine management is electronic but cant be sure i keep finding two pin plugs everywhere not connected to anything.
Yipee i have the xant lets i hope i keep her this time
MikeT
- x 232
Synergietom
Synergietom
MikeT
- x 232
- x 8365
Synergietom
Synergietom
- x 8365
Have a look here Tom: Lexia Locations.
EDIT: If I recall correctly, a Lexia can exercise the EGR valve. Mike, can you confirm. It'll be under Actuator Tests...
Synergietom
Thanks Jim unfortuanately it looks like your the closest to me at 85 miles away which is a good hour and half drive.
Would you be able to plug it in for me and see if you cant come up with a solution to all my problems.
Ill be happy to pay for your help as im starting to get a bit fed up with the endless trail of iol running up my arm.
MikeT
- x 232
