strut top warnings
deian
Unread post by deian »
Would a series 2 V6 one fit? Are the holes the same (mounting/inlet/hole for the strut
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
That is under MASSIVE investigation at the Moment Dei!
Hence me saying earlyer, hold your horses..
Paul
A very sad...
1994 XM 2.1 d auto
x 8437
citroenxm wrote:That is under MASSIVE investigation at the Moment Dei!
Indeed, to goodness, yes., it is :wink:
deian
There is one on ebay from wosley (didn't u mention them the other day). Thx
deian
Are both sides different? I assume not, what is drivers side? off side?
deian
Well i've bought the one side i needed now off wolsey, should be with me in a couple of days, £65 (all in) for a part that i want is not too bad, i would assume those guys know they rust through so wouldn't sell a bad one
i will obviously check the other side in more detail after i've sorted this side out, it's not as bad as the drivers side one for some reason??
Xantidote
x 4
Unread post by Xantidote »
In a word, YES, they are different. It's something to do with the steering geometry.
If you purchase new, Citroen define them as left & right - check which is which. Last year, Citroen assumed I'd need new boot as well, which I accepted & fitted. Something I've read somewhere, maybe on this forum, about struggling to re-use original gaitor. I only made a very brief comparison of the old & new gaitor, but there might have been some subtle minor difference. Imagine Jim or Paul will know if you can refit original boot to new strut
Martin
1995 Xantia TDLX (deceased :( )
deian
i only got the top, i took the boot off, i think it's just the tight fit that makes people buy new ones, it catches on that white strip half way down the shaft yea
citroenxm
Fallen Hero
x 70
deian wrote:Well i've bought the one side i needed now off wolsey, should be with me in a couple of days, £65 (all in) for a part that i want is not too bad, i would assume those guys know they rust through so wouldn't sell a bad one
Dei,
Thats a little bit of a mistake! They are S2 Tops and WILL NOT GO ON DIRECTLY!
Hence my Under investigation post above..
So DO NOT get your hopes up incase you get disapointed..
Of course I DO Hope you proove me wrong, but so far Ive found the Pipe is slightly different on S2 tops...
Paul
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
My S1 TD SX, on 220k drivers side strut was in a similar state to that, however, having "Normal" suspension, I had a pair of S2 Tops and struts off a HDi, which fitted beautifully!!
But thats with Normal 3.5mm feed pipes..
Paul
A very sad...
1994 XM 2.1 d auto
deian
Well hopefully it will be ok, car not going anywhere any time soon, so got time to ffaff about till weekend.
citroenxm
Fallen Hero
x 70
Dei, if they were any good for S1 for defenate, I would have had them, Ive a customer waiting on a strut top for his VSX Estate, but wasn't going to buy untill Id FULLY investigated the difference and finding out a way of makingthem compatible..
Paul
A very sad...
1994 XM 2.1 d auto
deian
my thinking is that the 3.0i v6 will have hydractive 2 as well and as long as the holes line up and the pipe fits in and the strut comes through the top i should be ok
i think maybe the v6 version has a thicker base plate to support the extra weight, in which case my bolts won't go in deep enough, i can just pop to Citroen to get new ones
otherwise it could be just uprated metal and coatings for the mark 2 to prevent the rusting seen on the series 1.
who knows huh
citroenxm
Fallen Hero
x 70
No Dei..
THE PIPES HAVE DIFFERENT ENDS, can you not hear me? :shock: :lol: :lol:
S2 cars have DIFFERENT PIPE ENDS.... :roll:
Paul
A very sad...
1994 XM 2.1 d auto
deian
Well just noticed they don't say on the listing whether the V6 is a series 1 or a series 2, so we will see. They do returns too, I did ask them if it would fit and they said should do.
Just been on 'service.citroen.com' now, their part no. is 5271-F3, I need E5. I'll see if i can join some pipes from a series 2 to a series 1.
