x 8470
Paul-R wrote: 04 Jun 2023, 12:55
CitroJim wrote: 04 Jun 2023, 09:56Most creatures seem to have a purpose in nature, even the despised wasp...
Wasps are really the gardener's friend. They are carnivores and will take a lot of caterpillars to feed their grubs.
Exactly! They do no end of good :-D If only the vast majority realised that we might see a bit of love for them... Personally, I have to pussyfoot around them as I react badly to their stings but that does not stop me allowing them to over-winter in my workshop attic...
Not that I have much choice really...
x 8178
With no sign of the pigeon scaring tape today I turned my attention to the other issue which is currently irritating us, or more precisely irritating SWMBO. For the last couple of years she has been getting a damp patch appear on her bedroom wall on cold wet days. So far she has paid out a lot of money having the dormer flat roof above her bedroom completely stripped and relayed - no change, then she paid out to have the outside pointing redone - no change and finally we had the front plastic cladding joints resealed - no change!! This is the area in question in the red circle:
MTM Original
MTM Original
I decided it was time to cut a hole in the wall and examine it from the inside to see if I could find a damp trail, so I cut an inspection hole into the plasterboard:
MTM Original
MTM Original
Once cut through the apparently damp board I was surprised to find no damp at all through the board or on the back! Hmmm :?
Looking into the void the insulation is all dry and I could not see or smell any signs of damp! :)
MTM Original
MTM Original
However there was a constant cool breeze coming out of the void, convincing me that air was definitely coming into the void from outside. You can see the gap circled in the picture above which is a clear opening into next door's void. I could feel air coming into my face as I put it close to the hole, but I felt it coming from the right as well. I went out into the garden and examined all the joints between the dormer, the wall, the soffit and the window frame and there are cracks here and there. So I have formulated a plan for tomorrow:
I have three rolls of spare loft insulation left over from the re-insulation of the loft (we now have 18" throughout!) and about 5 cartridges of external sealant and two cartridges of No More Nails in stock as well as various timbers. I honestly believe that the drywall being exactly that, then the damp issue may well have been condensation all the time. My theory is that the draught in cold weather was making that particular piece of uninsulated plasterboard a cold spot within the wall and hence causing overnight breathing to condense there being much colder than the rest of the wall which runs behind the radiator.
My plan is to do my best to eliminate the draught by sealing the outside cracks around the soffits, blocking the gap to next door with a waterproof membrane covered timber and then once satisfied that the draught is gone I will stuff as much of the void as I can reach with the loft insulation before installing a new piece of plasterboard, patching the woodchip and painting. Fortunately the entire repair will end up behind the bedside cabinet when completed so a perfect matched finish isn't essential!! :-D
I will complete the story in due course, no doubt the tape will arrive tomorrow and give me a dilemma!! :-D
x 8178
Picking up from where I left off yesterday I got stuck in to repairing the holes today. Firstly I boarded up the gap through to the neighbour's void and then filled all the small crevices around with expanding foam:
MTM Original
MTM Original
While that was setting I went up in the loft to get the insulation rolls we had left over, 3 like this:
MTM Original
MTM Original
I only brought one down to begin with as the void is not that big and it sure expands when you unroll it!!
Next job was to suit myself up with all the PPE to manhandle the insulation in the confined space. I took the picture without the gauntlets, goggles and mask as I couldn't work the camera with them on:
MTM Original
MTM Original
Having put them on I got to work unrolling, and installing the insulation to completely fill the void:
MTM Original
MTM Original
Then it was down to B&Q to pick up the materials to make good and decorate which was a nice breath of air after doing the insulating. When I got home there was a packet on the doorstep containing my bird scaring tape which I set aside while making good the opening:
MTM Original
MTM Original
Having filled around the plasterboard I had to leave that to set before I can paper and paint it to finish the job.
Time to turn my attention to the bird scarer. My initial plan had been to hang lengths of the tape from the line down to the gutter but my first trial showed that to be ineffective so I have now put double tapes every metre or so along the line and hoisted it into place:
MTM Original
MTM Original
Initial results are promising, I aimed a spare motion detector, which does detect pigeon sized birds, at the roof and it has not sounded yet! Fingers crossed and see how it goes before I get the ladder up to make it all a more permanent installation!! :-D
x 8470
Gosh, you've been busy Mick :D Loving the suit!
Fingers crossed you've upset the pigeons enough they've gone to pastures (or roofs) new ;)
x 8178
Well the repair dried in time for me to get it papered and painted so the job is done!! The paint is still wet in the picture but my test blob earlier in the day just above the right end of the radiator has dried and blended a treat so I'm sure by tomorrow you'll never know I've been there :-D
MTM Original
MTM Original
and with everything returned to normal before she gets home, job's a goodun!! :-D
MTM Original
MTM Original
x 8470
Excellent!
x 8178
Well I am pleased to report that there were no pigeons at all on the roof at bird feeding time this morning!! :-D There used to be a fair flock of 30+ so I am very pleased with that project and the hassle was well worth while!! :bd: :bd: :bd:
However I am not sure our neighbour at the back of our garden will be impressed! They have moved in there!!:
MTM Original - Neighbour's new extension
MTM Original - zoomed in
x 8470
As they move Mick, you can earn some pocket-money by installing your patent deterrent on houses so affected ;)
x 8178
Just imagine all the houses on our estate sporting metallic tape ribbons over the roofs!!! If Putin decides to have a go at us at least it might confuse their radar!!! :-D
x 1083
Unread post by Rp0thejester »
:rofl2: :rofl2: :rofl2: I'm not sure if you're more concerned on how to take a photo on your phone or about the job your about to do :rofl2:
x 3298
mickthemaverick wrote: 06 Jun 2023, 20:08 Just imagine all the houses on our estate sporting metallic tape ribbons over the roofs!!! If Putin decides to have a go at us at least it might confuse their radar!!! :-D
And if you hang it up by all the glazing in your house you would have 'Window' by the windows!
x 5691
What about some of these, sparkly ones ideally.
x 2938
In my cherry tree I hang old CDs on string. worked for a while but the birds soon returned to nicking the cherries. :(
Sloppysod
x 407
Unread post by Sloppysod »
Tried Christmas bubbles, no luck😕.
So we now use the "they don't like it up 'em" method, when they arrive in our tree we sneak out with a long pole, it's so satisfying to poke them 😂, and oh boy, do they fly off quick.
However, I'm glad my car lives in the garage due to the occasional ' 💩'
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 3298
You could always try flying a cheap drone near them. I got a couple from ebay for under £30 each, and they come with three batteries, and two 4K cameras! One has an adjustable angle (you pivot the camera by hane before flying), and the other is pointing straight down.
