Timmycitroen
Bleed pipe for Citroen c4 grand Picasso mk2 2015
Unread post by Timmycitroen »
I am am after a part number for the bleed pipe that extends between concentric cylinder to the bleeding pipe
[with metal push clip and bleed port]
Vin
Thanks in advance
x 8139
Morning Marc/Richard. I have now got my C4 Vin no VF7**************[VIN obfuscated, can be read by forum staff].
It had the driver's door replaced and has no door sticker for the paint code. I believe it is KGN but could you confirm or correct as necessary as I am in need of a touch up aerosol asap. Thanks :)
x 6945
Bryonyolney wrote: 18 Jul 2024, 08:06 Morning!
I’m looking for 2 part numbers for VIN VF7**************[VIN obfuscated, can be read by forum staff]
1. Passenger side wing mirror casing
2. Drivers side scuttle drain cover
Hope you can help!
Bryony
Let me know the item number as, there isn't a 'casing' as such.
If (1) the complete Mirror, then part: 1685330580, £484.46
(10) Cowl Air Itake Grille (A + (11) & (12)), part: 1627700380, £289.15
(13) Air Inlet Grille Closer, part: 1613446280, £32.03
x 6945
mickthemaverick wrote: 18 Jul 2024, 11:47 Morning Marc/Richard. I have now got my C4 Vin no VF7**************[VIN obfuscated, can be read by forum staff].
Hi Mick
Yes: KGN - BOURRASQUE PAINT
x 6945
Re: Bleed pipe for Citroen c4 grand Picasso mk2 2015
Timmycitroen wrote: 18 Jul 2024, 11:39 I am am after a part number for the bleed pipe that extends between concentric cylinder to the bleeding pipe
Vin
Thanks in advance
(9) Clutch Bleed Union, part: 9676664180, £44.27
(11) Declutching COntrol Pipe, part: 9806928280, £69.67
(81) Pipe Support, part: 9675689580, £4.28
If anything other, let me know.
x 8139
Thanks Marc, a few more requests to come in a few days I suspect :-D
x 6945
mickthemaverick wrote: 18 Jul 2024, 12:22 Thanks Marc, a few more requests to come in a few days I suspect :-D
Just in case you need it for future ref., here's your build spec. sheet Mick:
Vehicle Characteristics
Vehicle familyC4
AS/RP N°11792 88 1 0229
Warranty Start Date24/03/2009
Engine serial number10 JBBN 0031223
OPBI5DP
BERe2*2001/116*0302*13
P4A9665084099
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC4
SILHOUETTE5 DOOR SALOON
TRIM LEVELVTR PACK
ENGINEDIESEL TURBO DV6TED4 FAP
TRANSMISSION6-SPEED CONTROLLED MANUAL GEARBOX
PAINT TYPEMETALLIC PAINTWORK
BODY COLOURKGN - BOURRASQUE PAINT
INTERIOR TRIM TYPEWEAVE 3D XRAY + CLOTH SPRINT "SR"
UPHOLSTERY COLOUR"FZ"
GEARBOX (CHARACTERISTICS)MCD MANUAL GEARBOX
DEFINITION TO FOLLOWRANGE ACTIVITY
ENGINE (TYPE)DV TYPE ENGINE
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
TRIM LEVELVTR PACK
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGE TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL)CRANKCASE ALUMINIUM
FUELDIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE)EURO 4 ENGINE EMISSION CONTROL
CAPACITY1600 CM3
OIL COOLERMNTG WATER/OIL EXCHANGER ON ENGINE
COOLING MOTORRADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
VEHICLE TECHNICAL DEPOLLUTIONL5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN2 FANS , 2 RATES , IMPROVED 130WAERO
FUEL VAPOUR RETRIEVALWITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
TANK FILTERRESERVOIR FILTER INTERIOR
Gearbox Transmission
FINAL DRIVE RATIOCP 19 X 71
WHEEL STYLERIBALTA 17 INCH WHEEL
CLUTCHWITHOUT CLUTCH
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 77
TYRE (SIZE, TYPE)205/50 R17 89W NON REINFORCED TYRE
WHEELS FITTED6,5" RIM ROAD WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 2
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPEMC MANUAL GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BARREAR ANTI ROLL BAR DIAM 27
STEERING COLUMNSTEERING COLUMN REINFORCED MANUAL ADJUSTMENT
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAMETER 22.5
POWER STEERING FLUID COOLING SYSTEMWITHOUT POWER STEERING OIL COOLING
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT8 1 BOSCH ESP
STEERING (OPERATION)ASSISTED ELECTROHYDRAULIC STEERING
PEDAL BRACKET (TYPE)PEDAL STANDARD
Body Fittings
HORNSHORNS-HARMONY
AERIALSHORT ROOF AERIAL
REAR SPOILERFITTING WITH RR UPPER DEFLECTOR
DECORATION (PAINTED)SOLID COLOUR DECOR
SIDE MOULDINGS (TYPE)LATERAL PROTECTOR MASS TINTED
SIDE MOULDINGS (DIMENSION)WITHOUT LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE)17 INCH CHROME CIRCLE
REVERSING LAMPSWITH 1 REVERSING LAMP
SILL ILLUMINATION LAMPWITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
DRAUGHT EXCLUSIONBONNET WITHOUT SEAL
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR MANUAL-FOLD BACK
EXHAUST TAILPIPE TRIMW/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFINGBONNET SOUNDPROOFING
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPERWITH REAR WIPER
HEADLAMP WIPERW/O HEADLAMP WIPER
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
REAR TAILGATE GLASSFIXED TAILGATE WINDOW
BUMPERFR/RR BUMPER STD BODY COL+FOG LAMP TRIM CHROME
MUDFLAPWITHOUT REAR MUDGUARD
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPFRONT FOG LIGHTS
SPARE WHEELREDUCED STEEL WHEEL + NON STD TYRE
EXTERIOR ACCESSORIESBODY COLOUR EXT HANDLE+RR CTRL+PILLAR+ MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)CURVED EXTERIOR MIRROR GLASS
SUN ROOFFIXED ROOF
BUMPER TRIMBODY COLOUR BUMPER STRIP
GLASS (APPEARANCE)TINTED
WINDOW (TYPE)ACOUSTIC LAMINATED W/SCRREN+TOUGHENED SIDE RR
HANDS FREE ACCESS AND STARTINGNO ACCES AND HANDSFREE STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTERFRONT CIGAR-LIGHTER
REAR HEAD RESTRAINTREAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINTJOINTED FRONT HEADREST
REAR SEATSEPA FOLDING CUSHION + SEPA FOLDING SEAT BACK
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
REAR SEATBELTREAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELTPYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
TACHOMETERINTEGRATED DIGITAL REV COUNTER
DRIVING POSITIONRIGHT HAND DRIVE
ADDITIONAL HEATINGAUTOMATIC ADDITIONAL HEATING
DASHBOARD EQUIPMENTFASCIA MULTICUB LOW CTRL PANEL+PEN HOLDER PAINTED
MISC. INT. LAMPS3-POSITION FR COURTESY LAMP
DOOR TRIMDOOR PANEL WITHOUT WOOD DECOR
LOUDSPEAKER4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLSREMOTE RADIO CONTROL
PASSENGER COMPARTMENT SOUNDPROOFING6 KG BULKHEAD SOUNDPR
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF)WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROLWITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROLDRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENTDRIVER’S LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTWITHOUT PASSENGER’S SIDE AND LUMBAR SUPPORTS
DRIVER’S SEAT FOLDINGW/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDINGW/O FOLDING PASS FRONT SEATING
FRONT SEAT ARMRESTCENTRAL ARMREST
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
HEADLAMP BULBSHALOGEN BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERWITHOUT LATERAL TRAJECTORY MONITORING
DISPLAYDISPLAY (RADIO+CLOCK,T°,CD)
COURTESY MIRRORDRIV OCCULT+PASS OCCULT W/O LIGHT
OIL GAUGESTD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGTHORAX SIDE + CURTAIN AIRBAG
PASSENGER AIRBAGPASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION)DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
EQUIPMENT PACKWITHOUT DRIVING SCHOOL EQUIPMENT PACK
EXTERIOR REAR VIEW MIRROR (HEATED)NON HEATED DOOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)SOFT MISTRAL APPEARANCE INTERIOR DOOR CONTROL
REAR LOAD FLOORWITHOUT REAR LOAD FLOOR
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARDWITHOUT CAB PROTECTION PANEL
FRONT SUN VISORDRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION
STORAGE (DRIVING POSITION)CLOSED SIDE STORAGE COMPARTMENT WITHOUT BEZEL
RADIO RECEIVER"RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLREGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROLPARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
CARPET COVERW/O CARPETMAT
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGEW/O BOOT TIDY
CARPETNEEDLED CARPET DILOUR F550
TUNER RADIOMONO RADIO TUNER
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
TRIM ADAPTATIONGEAR LEVER KNOB CHROME INSERT
FLOOR MATW/O CARPETMAT
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
LOCKING CONTROLDEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL2 SPOKE LEATHER STEERING WHEEL WITH DECOR
CHILD OBSERVATION INTERIOR MIRRORWITHOUT INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKETWITHOUT AUDIO PACK AUXILIARY SOCKET
TELEMATIC UNITWITHOUT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR 150 AMP
HORNSHORNS-HARMONY
BATTERYBATTERY L3 450
STARTER MOTORSTARTER MOTOR CL 5
SPECIAL LIGHTINGAUTOMATIC HEADLAMP ILLUMINATION
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
MULTIPLEXINGMULTIPLEXING ASSEMBLY CAN CAN
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
RADIO HEADPHONE SOCKETWITH ACCESSORIES SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSDOOR WITHOUT REINFORCEMENT
SET OF KEYS1 HF PLIP KEY + 1 SINGLE MAIN KEY
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
SLAVE CONTROL UNITBSI EVOLUTION
EMERGENCY WARNING TRIANGLEWITHOUT WARNING TRIANGLE
x 8139
Thanks very much for that Marc, not only will it be good info going forward but it will also save me relating what it has and has not got!! :-D
However I have just given it a 50 mile shakedown cruise and I do need to replace the offside front strut top mount so a part number for that would be very helpful. Cheers :)
x 6945
This is the strut with an integral mounting if this is what you mean:
(1) Front Right Strut
OEM, part: 5202WN, £86.66
PSA Alternative, part: 1674698480, £77.39
The other parts are under the spring:
(10) Front Shock Absorber Mounting (Includes all elements shown under (10) on diagram, part: 5031E9, £64.62
(3) Front Suspension Rest Cup, part: 503151, £30.90
(6) Front Bump Stop Cup, part: 503371, £17.89
GORAX
x 14
Unread post by GORAX »
Hi Guys,
Can I get the part number for my BSI?
GOOGLE TRANSLATE
x 8139
Thanks again Marc, part now ordered. :-D
Bryonyolney
Unread post by Bryonyolney »
Thanks Marc, amazingly helpful as always!
Re the mirror casing, it’s the plastic back of (1) that is damaged. I’ve found what I guess are after market replacements for the back of the mirror casing and bought a short arm one so hope there’s some way of removing the damaged bit and attaching the new part. I assume if they sell them, there is!
x 1493
GORAX wrote: 18 Jul 2024, 20:42 Hi Guys,
In the UK it's £519.44 new or £327.44 exchange. This is not plug and play, and needs coding.
x 2356
Unread post by MattBLancs »
Good morning
Peugeot 308 SW 2.0 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Could you confirm part numbers for the following please:
Right and left drive shafts, also if there's any supplementary info e.g. length etc that would help me confirm aftermarket options that will be good too.
Ah, update: I don't think the outer CV joints are listed separately but if they are part numbers for these too please
Is the start button listed as a separate part or part of the whole expensive switch unit? ( Mine is a bit worn)
Thank you :)
x 1493
Matt
Driveshafts:
Prices :twisted:
No sizing info. They appear to be specific to this car and gearbox combo.
Start button - £44.26:
Edit: button also used on 2008 and 208 which might widen the search for a 2nd hand one.
