Timmycitroen
Bleed pipe for Citroen c4 grand Picasso mk2 2015
I am am after a part number for the bleed pipe that extends between concentric cylinder to the bleeding pipe
[with metal push clip and bleed port]
Vin
Thanks in advance
Vin
Thanks in advance
- x 8132
Morning Marc/Richard. I have now got my C4 Vin no VF7**************[VIN obfuscated, can be read by forum staff].
It had the driver's door replaced and has no door sticker for the paint code. I believe it is KGN but could you confirm or correct as necessary as I am in need of a touch up aerosol asap. Thanks
- x 6945
Let me know the item number as, there isn't a 'casing' as such.Bryonyolney wrote: 18 Jul 2024, 08:06 Morning!
I’m looking for 2 part numbers for VIN VF7**************[VIN obfuscated, can be read by forum staff]
1. Passenger side wing mirror casing
2. Drivers side scuttle drain cover
Hope you can help!
Bryony
If (1) the complete Mirror, then part: 1685330580, £484.46
(10) Cowl Air Itake Grille (A + (11) & (12)), part: 1627700380, £289.15
(13) Air Inlet Grille Closer, part: 1613446280, £32.03
- x 6945
Hi Mickmickthemaverick wrote: 18 Jul 2024, 11:47 Morning Marc/Richard. I have now got my C4 Vin no VF7**************[VIN obfuscated, can be read by forum staff].
It had the driver's door replaced and has no door sticker for the paint code. I believe it is KGN but could you confirm or correct as necessary as I am in need of a touch up aerosol asap. Thanks![]()
Yes: KGN - BOURRASQUE PAINT
- x 6945
Re: Bleed pipe for Citroen c4 grand Picasso mk2 2015
(9) Clutch Bleed Union, part: 9676664180, £44.27Timmycitroen wrote: 18 Jul 2024, 11:39 I am am after a part number for the bleed pipe that extends between concentric cylinder to the bleeding pipe
Vin
Thanks in advance
(11) Declutching COntrol Pipe, part: 9806928280, £69.67
(81) Pipe Support, part: 9675689580, £4.28
If anything other, let me know.
- x 8132
Thanks Marc, a few more requests to come in a few days I suspect
- x 6945
Just in case you need it for future ref., here's your build spec. sheet Mick:mickthemaverick wrote: 18 Jul 2024, 12:22 Thanks Marc, a few more requests to come in a few days I suspect![]()
| Vehicle Characteristics | |
| Vehicle family | C4 |
| AS/RP N° | 11792 88 1 0229 |
| Warranty Start Date | 24/03/2009 |
| Engine serial number | 10 JBBN 0031223 |
| OPB | I5DP |
| BER | e2*2001/116*0302*13 |
| P4A | 9665084099 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C4 |
| SILHOUETTE | 5 DOOR SALOON |
| TRIM LEVEL | VTR PACK |
| ENGINE | DIESEL TURBO DV6TED4 FAP |
| TRANSMISSION | 6-SPEED CONTROLLED MANUAL GEARBOX |
| PAINT TYPE | METALLIC PAINTWORK |
| BODY COLOUR | KGN - BOURRASQUE PAINT |
| INTERIOR TRIM TYPE | WEAVE 3D XRAY + CLOTH SPRINT "SR" |
| UPHOLSTERY COLOUR | "FZ" |
| GEARBOX (CHARACTERISTICS) | MCD MANUAL GEARBOX |
| DEFINITION TO FOLLOW | RANGE ACTIVITY |
| ENGINE (TYPE) | DV TYPE ENGINE |
| OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
| Fuel Supply-Engine | |
| FUEL SUPPLY | DIRECT EXCHANGE TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| CYLINDER BLOCK (MATERIAL) | CRANKCASE ALUMINIUM |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 4 ENGINE EMISSION CONTROL |
| CAPACITY | 1600 CM3 |
| OIL COOLER | MNTG WATER/OIL EXCHANGER ON ENGINE |
| COOLING MOTOR | RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM |
| CRANKCASE GAS CIRCUIT HEATING | W/O HEATER CASING GAS CIRCUIT |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
| VEHICLE TECHNICAL DEPOLLUTION | L5 VEHICLE TECHNICAL DEPOLLUTION |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 2 FANS , 2 RATES , IMPROVED 130WAERO |
| FUEL VAPOUR RETRIEVAL | WITHOUT PETROL VAPOUR RECUPERATION |
| INJECTION ASSOCIATED VARIANT | MOUNTING BOSCH |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | CP 19 X 71 |
| WHEEL STYLE | RIBALTA 17 INCH WHEEL |
| CLUTCH | WITHOUT CLUTCH |
| DIFFERENTIAL (GEARBOX) | DIFFERENTIAL 77 |
| TYRE (SIZE, TYPE) | 205/50 R17 89W NON REINFORCED TYRE |
| WHEELS FITTED | 6,5" RIM ROAD WHEELS |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 2 |
| INFLATION PRESSURE LOSS INDICATOR | WITHOUT TYRE DEFLATION INDICATOR |
| GEARBOX TYPE | MC MANUAL GEARBOX |
| Suspension-Steering-Brakes | |
| REAR ANTI-ROLL BAR | REAR ANTI ROLL BAR DIAM 27 |
| STEERING COLUMN | STEERING COLUMN REINFORCED MANUAL ADJUSTMENT |
| FRONT ANTI-ROLL BAR | FRONT ANTI-ROLL BAR DIAMETER 22.5 |
| POWER STEERING FLUID COOLING SYSTEM | WITHOUT POWER STEERING OIL COOLING |
| SUSPENSION | NORMAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| BRAKE ASSOCIATED VARIANT | 8 1 BOSCH ESP |
| STEERING (OPERATION) | ASSISTED ELECTROHYDRAULIC STEERING |
| PEDAL BRACKET (TYPE) | PEDAL STANDARD |
| Body Fittings | |
| HORNS | HORNS-HARMONY |
| AERIAL | SHORT ROOF AERIAL |
| REAR SPOILER | FITTING WITH RR UPPER DEFLECTOR |
| DECORATION (PAINTED) | SOLID COLOUR DECOR |
| SIDE MOULDINGS (TYPE) | LATERAL PROTECTOR MASS TINTED |
| SIDE MOULDINGS (DIMENSION) | WITHOUT LATERAL PROTECTORS |
| WHEEL EMBELLISHER (STYLE) | 17 INCH CHROME CIRCLE |
| REVERSING LAMPS | WITH 1 REVERSING LAMP |
| SILL ILLUMINATION LAMP | WITHOUT SILL ILLUMINATION |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| DRAUGHT EXCLUSION | BONNET WITHOUT SEAL |
| EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR MANUAL-FOLD BACK |
| EXHAUST TAILPIPE TRIM | W/O EXHAUST OUTLET EMBELLISHER |
| ENGINE BAY SOUNDPROOFING | BONNET SOUNDPROOFING |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| REAR SCREEN WIPER | WITH REAR WIPER |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| ROOF GLASS | WITHOUT ROOF WINDOW |
| REAR TAILGATE GLASS | FIXED TAILGATE WINDOW |
| BUMPER | FR/RR BUMPER STD BODY COL+FOG LAMP TRIM CHROME |
| MUDFLAP | WITHOUT REAR MUDGUARD |
| NUMBER PLATE | WITHOUT LICENCE PLATE |
| LUGGAGE RACK | WITHOUT ROOF BARS |
| FRONT FOGLAMP | FRONT FOG LIGHTS |
| SPARE WHEEL | REDUCED STEEL WHEEL + NON STD TYRE |
| EXTERIOR ACCESSORIES | BODY COLOUR EXT HANDLE+RR CTRL+PILLAR+ MIRROR |
| EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | CURVED EXTERIOR MIRROR GLASS |
| SUN ROOF | FIXED ROOF |
| BUMPER TRIM | BODY COLOUR BUMPER STRIP |
| GLASS (APPEARANCE) | TINTED |
| WINDOW (TYPE) | ACOUSTIC LAMINATED W/SCRREN+TOUGHENED SIDE RR |
| HANDS FREE ACCESS AND STARTING | NO ACCES AND HANDSFREE STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITHOUT THEFT PROTECTION ALARM |
| CIGAR LIGHTER | FRONT CIGAR-LIGHTER |
| REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
| FRONT HEAD RESTRAINT | JOINTED FRONT HEADREST |
| REAR SEAT | SEPA FOLDING CUSHION + SEPA FOLDING SEAT BACK |
| REAR SEAT ARMREST | WITH REAR SEAT ARMREST |
| REAR SEATBELT | REAR 3-POINT 3 INERTIA REEL SEAT BELT |
| FRONT SEATBELT | PYROTECHNIC SEAT BELT WITH ALARM |
| CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
| CHILD LOCK | ELECTRIC REAR CHILD LOCK |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| TACHOMETER | INTEGRATED DIGITAL REV COUNTER |
| DRIVING POSITION | RIGHT HAND DRIVE |
| ADDITIONAL HEATING | AUTOMATIC ADDITIONAL HEATING |
| DASHBOARD EQUIPMENT | FASCIA MULTICUB LOW CTRL PANEL+PEN HOLDER PAINTED |
| MISC. INT. LAMPS | 3-POSITION FR COURTESY LAMP |
| DOOR TRIM | DOOR PANEL WITHOUT WOOD DECOR |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| RADIO CONTROLS | REMOTE RADIO CONTROL |
| PASSENGER COMPARTMENT SOUNDPROOFING | 6 KG BULKHEAD SOUNDPR |
| SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) | WITHOUT SUN VISOR SCREEN |
| FRONT PASSENGER SEAT HEIGHT CONTROL | WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| FRONT PASSENGER SEAT CONTROL | PASSENGER FRT SEAT MANUAL CNTR |
| DRIVER SEAT ADJUSTMENT | DRIVER’S LUMBAR SUPPORT |
| FRONT PASSENGER SEAT ADJUSTMENT | WITHOUT PASSENGER’S SIDE AND LUMBAR SUPPORTS |
| DRIVER’S SEAT FOLDING | W/O FOLDING DRIV FRONT SEATING |
| FRONT PASSENGER SEAT FOLDING | W/O FOLDING PASS FRONT SEATING |
| FRONT SEAT ARMREST | CENTRAL ARMREST |
| COMPACT DISC | WITHOUT COMPACT DISC |
| SATELLITE NAVIGATION SYSTEM | WITHOUT NAVIGATION SYSTEM |
| HEADLAMP BULBS | HALOGEN BULB |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| TRAFFIC INFORMATION READER | WITHOUT LATERAL TRAJECTORY MONITORING |
| DISPLAY | DISPLAY (RADIO+CLOCK,T°,CD) |
| COURTESY MIRROR | DRIV OCCULT+PASS OCCULT W/O LIGHT |
| OIL GAUGE | STD OIL LEVEL INDICATOR |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| PASSENGER AIRBAG | PASSENGER AIRBAG |
| ELECTRIC WINDOW (OPERATION) | DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
| EQUIPMENT PACK | WITHOUT DRIVING SCHOOL EQUIPMENT PACK |
| EXTERIOR REAR VIEW MIRROR (HEATED) | NON HEATED DOOR MIRROR |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| INTERIOR DOOR CONTROL (APPEARANCE) | SOFT MISTRAL APPEARANCE INTERIOR DOOR CONTROL |
| REAR LOAD FLOOR | WITHOUT REAR LOAD FLOOR |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| FRONT SEAT GUARD | WITHOUT CAB PROTECTION PANEL |
| FRONT SUN VISOR | DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION |
| STORAGE (DRIVING POSITION) | CLOSED SIDE STORAGE COMPARTMENT WITHOUT BEZEL |
| RADIO RECEIVER | "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM |
| REFRIGERATION | SINGLE AIR CONDITIONING |
| CRUISE CONTROL | REGULATOR AND SPEED LIMIT |
| DRIVER’S SEAT HEIGHT CONTROL | PARALLEL DRV HEIGHT ADJ |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| CARPET COVER | W/O CARPETMAT |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| LOAD SPACE STORAGE | W/O BOOT TIDY |
| CARPET | NEEDLED CARPET DILOUR F550 |
| TUNER RADIO | MONO RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | WITHOUT OBSTACLE DETECTOR |
| TRIM ADAPTATION | GEAR LEVER KNOB CHROME INSERT |
| FLOOR MAT | W/O CARPETMAT |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| LOCKING CONTROL | DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | 2 SPOKE LEATHER STEERING WHEEL WITH DECOR |
| CHILD OBSERVATION INTERIOR MIRROR | WITHOUT INTERIOR CHILD MONITORING MIRROR |
| AUDIO PACK AUXILIARY SOCKET | WITHOUT AUDIO PACK AUXILIARY SOCKET |
| TELEMATIC UNIT | WITHOUT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ALTERNATOR 150 AMP |
| BATTERY | BATTERY L3 450 |
| STARTER MOTOR | STARTER MOTOR CL 5 |
| SPECIAL LIGHTING | AUTOMATIC HEADLAMP ILLUMINATION |
| CEN. LOCKING REM CONTROL FREQUENCY | LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE |
| MULTIPLEXING | MULTIPLEXING ASSEMBLY CAN CAN |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| RADIO HEADPHONE SOCKET | WITH ACCESSORIES SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SIDE IMPACTS | DOOR WITHOUT REINFORCEMENT |
| SET OF KEYS | 1 HF PLIP KEY + 1 SINGLE MAIN KEY |
| EMERGENCY EQUIPMENT | W/O HELP EQUIPMENT |
| SURFACE CONDITIONS | GOOD TERRAIN |
| SLAVE CONTROL UNIT | BSI EVOLUTION |
| EMERGENCY WARNING TRIANGLE | WITHOUT WARNING TRIANGLE |
- x 8132
Thanks very much for that Marc, not only will it be good info going forward but it will also save me relating what it has and has not got!!
However I have just given it a 50 mile shakedown cruise and I do need to replace the offside front strut top mount so a part number for that would be very helpful. Cheers
- x 6945
This is the strut with an integral mounting if this is what you mean:
(1) Front Right Strut
OEM, part: 5202WN, £86.66
PSA Alternative, part: 1674698480, £77.39
The other parts are under the spring:
(10) Front Shock Absorber Mounting (Includes all elements shown under (10) on diagram, part: 5031E9, £64.62
(3) Front Suspension Rest Cup, part: 503151, £30.90
(6) Front Bump Stop Cup, part: 503371, £17.89
GORAX
- x 14
Hi Guys,
Can I get the part number for my BSI?
GOOGLE TRANSLATE
- x 8132
Thanks again Marc, part now ordered.
Bryonyolney
Thanks Marc, amazingly helpful as always!
Re the mirror casing, it’s the plastic back of (1) that is damaged. I’ve found what I guess are after market replacements for the back of the mirror casing and bought a short arm one so hope there’s some way of removing the damaged bit and attaching the new part. I assume if they sell them, there is!
- x 1490
In the UK it's £519.44 new or £327.44 exchange. This is not plug and play, and needs coding.
- x 2356
Good morning
Peugeot 308 SW 2.0 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Could you confirm part numbers for the following please:
Right and left drive shafts, also if there's any supplementary info e.g. length etc that would help me confirm aftermarket options that will be good too.
Ah, update: I don't think the outer CV joints are listed separately but if they are part numbers for these too please
Is the start button listed as a separate part or part of the whole expensive switch unit? ( Mine is a bit worn)
Thank you
Thank you
- x 1490
Matt
Driveshafts:
Prices
No sizing info. They appear to be specific to this car and gearbox combo.
Start button - £44.26:
Edit: button also used on 2008 and 208 which might widen the search for a 2nd hand one.
Driveshafts:
Prices
