I am an Activaist-v6 and a 2.1Estateerr
Michel
Re: I am an Activa owner...a V6 and I am an addict
Unread post by Michel »
Stickyfinger wrote: 24 Nov 2017, 19:54 Anybody know if Xantia "big" callipers and disks fit a ZX ?
I'd be surprised. There'd also be the extra handbrake bits on the calipers to remove/disable.
306 bits should be a straight swap though...
x 1999
Unread post by Stickyfinger »
Oh yeh ....thick as mince me :)
x 8353
Unlikely as there may be a wheel clearance issue... Xantia big brakes are seriously big...
However, standard-sized Activa calipers may... I have a set of those still sitting on my workshop floor following doing the big brake update to Zel's Activa... If you want to see if they will work on a ZX you can have them with pleasure...
As you say Mike, handbrake mechanisms might pose difficulties...
x 1999
Well that was strange.....
Just did a little trip out for milk to the garage 4 miles down the road....all was well
Came out, keyed in the code, started the engine, 2/3 fires then it died !
Check fuel pump, nope, that was working.
Did a battery off, no change
Pulled all fuses, no change
Pulled relays, no change....still not starting.
Waited with battery off, nope, no start after 10mins.
Put all tools away, closed boot ready to go home and recover it tomorrow, I thought "oh one last try".....yep, it started !
x 1450
Unread post by xantia_v6 »
Which car?
x 1999
the Activa
x 1450
I have heard that the ES9 is prone to flooding, but it is not something that I have experienced often.
x 1999
It did not "sound" like that.....it ran 2 / 3 turns then died......I would bet 90% electrical. Like the fuel pump was not working.
x 8353
It's happened to me Alasdair, exactly that.... It was so bad with me on one occasion I thought the timing belt had snapped...
Most of my ES9-enginjed cars often suffered a very rough idle when started from half-hot - the idle speed swing between about 250rpm and 900rpm until it got itself sorted out...
PSA engines just don;t like starting when half-hot :twisted:
Just one of its quirks...
x 1999
Oh good, I have been quirked ....whatever that is :)
x 8353
Stickyfinger wrote: 26 Nov 2017, 09:11 Oh good, I have been quirked ....whatever that is :)
You were quirked the day you chose to buy an Activa ;)
x 1999
This is true :)
x 1999
Is that a tear in Stewart's eye ?
All loaded for the long trip to its new home
x 8353
Re: I am an Activa owner...a V6 and I am an addict (as I now have an AX and ZX as well)
Excellent!
x 3304
Methinks Alsadair has a thing for 'X' Citroen vehicles! Anybody got a BX, CX or XM they want to pass onto a good home? He might be your man!
