Death of another Activa now double trouble
holmedog
x 5
Re: Death of another Activa now double trouble
Unread post by holmedog »
Does anybody know if the Activa has a pressure release valve on the fuel tank. As the fuel tank looks fine. Not able to look at the top just yet as can't afford to disturb hydraulic pipes just yet.
Sent from my GT-I8200N using Tapatalk
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
x 8397
Not really but it does have a breather...
Why do you ask?
holmedog
x 5
Was told that it could possibly be that, that is leaking the fuel out. Something to do with the pressures in the tank. Do you know where the breather pipe goes to. Because the fuel always comes out in front of the rear wheel.
KP
x 27
Unread post by KP »
The breather and filler pipe run up the wheel arch from the tank. I'd be tempted to take the wheel off and see where it comes from when running or pressurise the system maybe from the engine return line
holmedog
x 5
It only leaks when i first fuel up and not when running.
x 1996
Unread post by Stickyfinger »
Have you checked the seal on the top of the tank (where the pump fits) ?....
Rule of thumb, never fill more than the first pump shut off.
KP
x 27
Unread post by KP »
If the ring seal was gone it would leak from driving surely unless giffer driven....
holmedog
x 5
It leaks even when i put £10-£15 in from empty. Reserve light on that is
KP
x 27
Unread post by KP »
I think the filler pipe is either ruptured or loose. Take the wheel off and stick a Jerry cans worth in and see
holmedog
x 5
Well could be adding to my collection of xantia's with an exclusive hdi from Mr.Newbold.just doing research as to the fixes it may need before I go ahead with the purchase.
x 8397
holmedog wrote:Well could be adding to my collection of xantia's with an exclusive hdi from Mr.Newbold.just doing research as to the fixes it may need before I go ahead with the purchase.
Excellent :D HG is not hard on an HDi ;)
holmedog
x 5
Thought easier and cheaper to do full engine swop as can get an engine for less than £100. Just waiting to here back from a lad I know who probably fit it for me. 8-[
holmedog
x 5
Well i am now the pride owner of a xantia EXCLUSIVE. This purchase intern allows me to take the blue Activa off road for the winter and start work on the few issues that have arisen this summer mainly all the spheres need to be replaced along with some hydraulic pipes i am sure you have all seen the pictures of said hydraulic pipe work nicely corroded. Also the fuel leek that turns out to be the coller on the filler pipe.
So hopefully that will all be addressed this winter and it will be back on the road in time for the summer i hope. And so should the silver Activa which will hopefully have it's hole in the rear wing all cut out and a new piece put in it's place.
Funds and time permitting i should have three cars on the road by this time next year. The exclusive will become the main run around and the two Activae will be put on classic car insurance. and with any look will be seen next year at one two rallye's.
I am just in the process of trying to get rhz engine for the exclusive so this can be on the road asap.
x 8397
Excellent :D I'm doing similar with the recent acquisition of Gabriel, a 1.9TD Xantia...
The HDi Exclusive will be a lovely car when sorted :D
Is the HDi engine a write-off then? If yo why?
holmedog
x 5
More mayonnaise than you can shake a stick at. Apparently cost of new head gasket is around £600 +. So engine exchange is the only way forward. My mechanic say's if i help him do the job it just £10 an hour for his time and he is confident that we can do it in a day, two top's.
