3008 engine vibration
owl
x 15
Re: 3008 engine vibration
Unread post by owl »
All values are perfect. But I see presence of water in fuel. Needs urgent action.
TeodorM
Unread post by TeodorM »
Yeah, I noticed that. It’s strange because I don’t have any warning lights on the dashboard. The fuel filter was replaced a few months ago when I carried out the service.
What would be the best approach in this situation? Should I open the fuel filter housing and check for signs of water contamination? Would it be advisable to replace the filter again?
Also, where could the water in the fuel system come from?
Is it worth using some additive to remove any water from ghe system?
Many thanks.
owl
x 15
I would buy Wynn’s dry fuel. Change filter and check water in tank.
I recommend you to change your gas station :)
TeodorM
I had a quick look at my fuel filter and I don't believe there is a sensor for water detection. It looks exactly the same as the photo.
I hope it's got a blank plug at least.
Anyway I will change the filter and add that additive this weekend and hope it will help 🤞
TeodorM
Hi all,
I replaced the fuel filter today, cleaned the housing and added the additive. I couldn't see any signs of water in the diesel. As I mentioned previously, there is no water-in-fuel sensor fitted either.
I'm starting to run out of ideas now. 🤦
Many thanks.
owl
x 15
It looks like we're back to square one, unfortunately. We must have missed something.
