3008 engine vibration
owl
- x 15
Re: 3008 engine vibration
All values are perfect. But I see presence of water in fuel. Needs urgent action.
TeodorM
Yeah, I noticed that. It’s strange because I don’t have any warning lights on the dashboard. The fuel filter was replaced a few months ago when I carried out the service.
What would be the best approach in this situation? Should I open the fuel filter housing and check for signs of water contamination? Would it be advisable to replace the filter again?
Also, where could the water in the fuel system come from?
Is it worth using some additive to remove any water from ghe system?
Many thanks.
Many thanks.
owl
- x 15
I would buy Wynn’s dry fuel. Change filter and check water in tank.
I recommend you to change your gas station
