RD4 => RD45 in my T7 307 worked when first installed but not now
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
ozfrog
(Donor 2026)
x 84
Re: RD4 => RD45 in my T7 307 worked when first installed but not now
Unread post by ozfrog »
shtu wrote: 16 Jun 2026, 22:04 That's a very limited list of settings, an RD45 has a lot more going on.
I'm curious now. If it isn't too inconvenient for you, would you mind showing me what your settings screen for an RD45 looks like?
My only observation is 7.02 is a very old version, I use 7.62 without issue.
I agree that 7.02 is very old! But I have been repeatedly told, both on this forum and elsewhere, that this is the latest version I need for my 'old' cars!
I do have a 9.x version available to me. It was sent by a former Peugeot technician who I've been advised also includes a lot of bloatware. There's nothing malicious, just bloat. I've chosen not to run that versionvor that reason, and also because the ancient Windows PC I own would probably die of heart failure, if I did ever try. I started a thread in the relevant forum some time ago looking for advice about updating that PC, but for various reasons, I ended up being more confused about what I should do than ever actually achieving anything along such lines. Plus, it's quite difficult to find PCs that are 32-bit machines these days.
Cheers,
Andrew
x 1481
Unread post by xantia_v6 »
You can see the RD45 config and BSI config of my 308 here: viewtopic.php?p=605092#p605092
ozfrog
(Donor 2026)
x 84
xantia_v6 wrote: 17 Jun 2026, 18:18 You can see the RD45 config and BSI config of my 308 here: viewtopic.php?p=605092#p605092
Thanks, Monsieur Xantia!
That’s a lot more info compared to what I got from my RD45. Is that because you have a later version of DiagBox? Or is it for some other reason?
I’m not sure where I go to from here to get the RD45 working again.
(Although, it isn’t the top priority right now. I had the front top suspension mounts replaced in December and one of them has already failed. I thought that SKF made better products …
And I’m also trying to figure out why both the right brake light and the right rear blinker have stopped working - at the same time. But both globes work when put into a different socket.)
Cheers,
Andrew
x 1481
I don't know, but I assume that it is either that your RD 45 is not very communicative or your BSI is somehow filtering the conversation.
ozfrog
(Donor 2026)
x 84
When I was searching for something completely unrelated, I saw a summary of a post(?) that mentioned resetting the RD45. But I was in a hurry with the other thing that I was doing, so I didn’t follow the rabbit hole and find out about resetting the RD45.
Does anyone here know what that’s about, and how it’s done? And might it actually achieve anything in my situation?
Cheers,
Andrew
ozfrog
(Donor 2026)
x 84
A recent development with my RD45. Nothing positive, unfortunately. More negative, in fact.
Since I haven't been able to use Bluetooth streaming with the RD45 natively, I've been using https://aerpro.com/fmt255 in the car and have tuned the FM radio to 88.1.
Everything has been working well until about two weeks ago.
My iPad seemed to lose connection with the device, and because I can't read the display in the car, I could never tell if the RD45 was actually on. My fail-safe way to know if the RD45 was turned on was to insert a CD, which automatically turned on the unit and began playing the CD. That worked until 2 days ago. Now I don't even know if the unit is turning on. The CD is being drawn into the unit, but there's no sound from the speakers.
I feel like there's a major fault with the RD45 now, but I am uncertain.
Also, in one of my earlier posts on this thread, I mentioned that I had changed the audio systems in each of my other Peugeots, but I couldn't find any of the original units, and I wasn't sure if they would be of any use anyway. I have now found the original unit from the 2003 406. One of the reasons it was removed is that the previous owner had a CD stuck inside it, and he didn't tell me that before I bought the car. Anyway, I have it, but as I said, I don't think it is of any use in my current situation.
Cheers,
Andrew
