Renault Kadjar - 2 auto electricians and no help
Mihael_M
x 37
Re: Renault Kadjar - 2 auto electricians and no help
Unread post by Mihael_M »
Did you read the oil pressure with OBD2 reader, which must be around 3 bars ?
The error is strange because it happens when the engine is not running and then there is no oil pressure.
That's why you should go back to the oil pressure sensor. According to the experiences of others, the problem is corrosion at the connection of the sensor with the mass. Below the sensor is a plate that gives it mass. You should check that connection.
andywilliams1187
Unread post by andywilliams1187 »
Thanks Mihael
Thats my next place to look - I am servicing the car in a couple of weeks so going to have a good look at it and then I may run a wire from the sensor to a seperate ground to see if that makes a difference.
I do have a video of the fault but can't seam to post mp4's on here
x 1939
Unread post by Paul-R »
You need to post your video on a site such as YouTube and then post a link to that video here.
andywilliams1187
Link to the video here:
Apologies Andy if this is a bit obvious and of little help! A simple brake pedal switch plays an important part in the successful start up of both my EV's, and if the pedal is not pressed which activates that switch as part of the start up, the car will not move an inch, drive and reverse cannot be selected.
Is it not the "normal" start up procedure for the Renault Kadjar that the brake pedal is required to be pressed for the start up to progress to a successful conclusion (that would seem to be confirmed by your video). If the start up does not proceed to s successful conclusion it may be expected that with no oil pressure, that the oil pressure sensor throws up the fault correctly.
Not sure how this would affect the "stop-start" triggered restart...presumably this would also require the brake pedal to be pressed, and if not the restart would fail...consequence no oil pressure, fault thrown up.
andywilliams1187
Hi Neil,
I thought along those lines intially that there may be an issue with the brake pedal, but the pedal has to be depressed in traffic for the stop/start to kick in and only restarts the vehicle when the pedal is released. Its a really bizarre issue - almost as if the sensor/ecu is not picking up that the vehicle is not running (but the ECU thinks it is) so notices a drop in oil pressure.
Will double check the grounds when I do an oil change in a couple of weeks
andywilliams1187
Hi all,
Been a while but just to update on this - it has been to two further mechanics and back to renault and no one can figure the fault out. Came to a head when I was travelling at 75mph down the M6 and the car went into limp mode with "Engine Hazard" message; after navigating over to the hard shoulder, turned the car off and back on and running fine.
Renault have suggested a new ECU and main wiring loom - decided instead to chop the car in and have now got rid of it
Real shame as I like how comfortable the car is, decent MPG with the 1.5 auto gearboxes but this is the second kadjar I have had that has developed major electrical issues between 40-60k miles.
