Peugeot Partner 2007 Brake Light Fault Help Please....
x 1056
Re: Peugeot Partner 2007 Brake Light Fault Help Please....
Unread post by wheeler »
It's fuses 20 & 21 in the BSI, this is located inside the car, not under bonnet.
The power to these fuses comes straight from the brake light switch.
Nisnool
Unread post by Nisnool »
Thanks for taking the time to advise. Once i had sorted out a dodgy multimeter lead, the task got easier! You were dead right, pin 2 on the plug became live after reseating the fuses and replacing the brake light pedal switch. It still didnt work though and took a replacement light cluster bulb holder to work, even though i couldnt see any breaks in the lines. So in actual fact 2/3 problems combined. You saved me a stack of time so extremely grateful for the effort. Best regards Mark
