Help required with warning lights
JackMa
x 4
Re: Help required with warning lights
Unread post by JackMa »
I get 0.2 ohms when I connect the leads together and then the reading immediately goes to zero.
I have tested another resistor of 1 KOhms and it works perfectly with that one measuring 1.001 kohms.
On a couple of resistors I have even tried to sand a bit both ends of each resistor thinking that they might be covered in a thin coat/film and then measured, but even that didn't work. :(
x 8106
That is quite bizarre. Have you tried a resistor both ways ie swap the leads? :)
Are you using the 200 ohm scale or the 2k one?
Can you post a pic of the resistor?
x 1487
Looks like all the belt pretensions have fired, they will need repairing / resetting.
JackMa
x 4
Morning All,
I'm a bit embarassed to admit that upon checking the resistors I bought, I realized that they were 2.2 M ohms and not 2.2 ohms.
That's why the multimeter didn't read anything.
I now bought another set of resistors of 2.2 ohms :)
x 8106
No need to be embarassed, it's easily done and is why I had asked you to post a pic of them so we could check the values by the colour code. Let's hope the new ones will solve your issue!! :)
JackMa
x 4
The 2.2 ohm resistors arrived and the airbag is not faulty!! :)
The problem was that the electrical connectors to the seat belts pretensioner weren't properly connected. I had to push them all way the in and that solved the issue.
The airbag warning light has now disappeared!! \:D/
I'm still working on the following warning lights:
- tyre under inflation detection system fault,
- Collision detection risk system fault,
- Automatic breaking system fault.
x 1487
What faults have you got left? Earlier pic showed an external temp sensor fault - this would upset the tyre pressure monitor.
