Gear knob removal...
x 1924
Re: Gear knob removal...
Unread post by Paul-R »
RichardW wrote: 23 Feb 2025, 18:11 It would appear heat is your friend....
Put the 3kW fan heater we use for defrosting the cars next to it for 10 mins, and it just came off in my hand
Oo-err missus.
RichardW wrote: 23 Feb 2025, 18:11 So we'll have to stop with the knob jokes now 😂
Never!
ozfrog
(Donor 2026)
x 75
Unread post by ozfrog »
That probably explains why I had relatively little trouble removing the knob in my 307. Heat is not usually in short supply in this country. England, on the other hand …
Cheers,
Andrew
x 1987
Unread post by Stickyfinger »
awwwa bolloc@ks. we had just got going....
x 1480
Well, my new knob works OK, but is not as tactile as my old one 😜
thorter
x 41
Unread post by thorter »
Leverage! Two feet of old 3x2 timber, drill hole 2 inches from the end, then slot out to the end by making two saw cuts. Size this to slide over the gear lever so that it can bear on the knob. Now a pile of bricks or whatever on the floor so you can lever the knob up, making sure you achieve a 5:1 mechanical advantage. Spead the load on the floor if you can see daylight coming up through it!
x 1480
That was my next plan, but the heat removed the need!
x 1924
Oo-err missus!
ekjdm14
x 257
Unread post by ekjdm14 »
Aw dammit I missed out on a good punfest... Was gonna say, the cold weather does tend to make ones knob shrink so no surprise it took some heat to win the day.
'96 ZX SX 1.9TD, White, 88k
'98 406sw 1.9TD, Cherry Red, 197k
'98 Ford Fiesta 1.3i 72k
'93 Ford Granada Scorpio 2.9i 135k
