Massive hydraulic Oil leakage
x 2007
Re: Massive hydraulic Oil leakage
Unread post by Stickyfinger »
MattBLancs wrote: 19 Jan 2025, 10:54
Stickyfinger wrote: 18 Jan 2025, 18:00 Yes, struts can be damaged by lifting the car off its wheels without raising the car to high before this is done (or fully depressurising)........good luck trying to prove it however !
Never heard that, what happens if I pass over a hump back bridge with enthusiasm!?
You bump your head, crash and are consumed in the resulting fireball :rofl2:
I suspect it is more to do with internal pressures generated within the "sealed" strut acting on the seals/bonding..... a change from Mk1/2/Xantia type struts that have free flowing open return ports/lines
Kees
x 150
Unread post by Kees »
The original struts on the car works fine at least 10 even so 15 years.
So this ones mentioned are faulty ones.
x 2007
Kees wrote: 19 Jan 2025, 12:36 The original struts on the car works fine at least 10 even so 15 years.
I can think of a few situations where that is not necessarily so certain.......... however it is most likely yes.
OZN
x 3
Unread post by OZN »
The problem was the strut indeed. Maybe a manufacturing defect (pictures attached), or the service didn't lift the car to the highest level.
However, yesterday I got help from a work colleague and I could drive the car! It feels good!
I have the new spheres in the box, but I guess I will wait a will till I will mount them on the car, as with so much going on yesterday, I still have to think and make courage to do that!
Citroen C5 (X7) 2.0, Diesel, 163 HP (Soft to 196 HP)
x 3298
Whoops! I hope that you got a full refund! You may still need to clean the pump motor, as it is possible it had LDS sprayed on it (and the motor is not sealed and has brushes).
OZN
x 3
No, I didn't and the supplier doesn't answer anymore.
I am still trying to figure out how to make a complain on eBay, as it seems they've hidden that button pretty well.
The seller's name is : top-quality-autoparts (ironical, right?). I strongly recommend avoinding them when ordering.
