C3 Picasso Blower Problem
PaulC5
x 696
Re: C3 Picasso Blower Problem
Unread post by PaulC5 »
If you open up the resistor pack you might be surprised, ours was a complicated printed circuit and not a few resistors that I was expecting. This helps explain the cost. I measured the resistance across all the pins on our old and new one and found on the old one the values kept changing and went open circuit which probably suggested a fault. You could try this on your old/replacement. Posted in this topic viewtopic.php?t=72595
