Ds 4 2010 audio denon does not work
gregy115
Re: Ds 4 2010 audio denon does not work
Today I connected the obd 2 to check the faults, It pop up the B1003, P2566 fault codes, the last one I know what it is, but that B1003 is missing in my mind
, is there a relay ore fuse malfunctioning?
- x 1953
B1003 is probably a phantom fault. If you put those two terms into the search you'll find a few posts to that effect.
gregy115
Hy guys, today I reconnected my DS4 to a better OBD reader, it says P0E69 error code, back right speaker, missing signal, is that a problem with the speaker or the amplifier? Can I just replace it with another, different speaker, or replace both rear speakers?, dis anione of you have this problem and that you solved it?
