Another dead RT6
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
x 1939
Re: Another dead RT6
Unread post by Paul-R »
You might find this YouTube video interesting. Although he doesn't reference it I'm pretty sure he's replacing an eMyWay (RT6) unit rather than the earlier MyWay one (faceplate visible at 2m 5s). Not that it should make any difference.
rich2222
Unread post by rich2222 »
clinch wrote: 28 Jul 2024, 15:04 Copy that Marc. Both of the USB-sticks were formatted to FAT32. I'm of the understanding that the LCD-screen itself is dead, so if it's possible to source a new one, I might try replacing just that...
I'm in the same boat. Unit spends 7 mins reading usb stick with 2.86 software on but then returns to original conition, blank screen, CD spinning up every few seconds.
Assume the unit is toast.
Seems odd for it to just completely fail. It's certainly doing something when the USB stick is plugged in.
Did you get any further?
x 6945
It may mean the internally stored data on the head unit is corrupt and unable to boot.
rich2222
clinch wrote: 28 Jul 2024, 15:28 Also, just so check it off the list.
Is it viable to source a used RT6 and LCD-screen from a "totaled" vehicle? I assume it's not exactly plug-and-play.
If anyone has experience with such a "transplant", I would love to hear more about it.
Have you tried taking the battery off the car for 24 hours? (Not just disconnecting the RT6).
My RT6 was dead - no screen. I accidentally let the battery go flat. Once recharged, the screen started working and the firmware update process worked. As my SD card was trashed, I had to use default config so the display came up in Czech. You need to use the mirascript and dataexplorer utilites (latest version) to enable language change on the head unit and then you can swap it back to your language.
