Citroen C5 x7 NG4 stereo
This unit is the NG4 system, made by Harman Becker.
Main Features: DVD, Voice Commands, HighRes Display, 3D Mapping, Bluetooth Hands Free, Independent Phone with MDS Module, SD Card, USB, Jukebox.
x 6945
Re: Citroen C5 x7 NG4 stereo
I'll sort this for you tomorrow when I have a bit of time.
No guarantee that reapplying the firmware will resolve anything if it's an internal issue or the hard drive is failing, but it won't cost you too much to do a CF card replacement as per the guide to see if this resolves it. Note: CF Cardc is recommended as it uses a compatible ATA command set for the PATA drive. Anything too fast or modern like an SSD or faster CF Card won't work for long due to TRIM not being supported by the OS.
Zolysys
Unread post by Zolysys »
Flash RAM faulty
x 6945
Depends what the problem is. It’s not always the internals but a corrupt HDD.
It’s easier and cheaper to try a CF Card replacement first. Reanimating the unit is not an option for most people who don’t have access to the software.
