Why some still insist the pedal should be pumped on the 2 clip system i domt know, plan for to day . Top up fluid leve clip out no pumping.
Will try fluid bowl cap on & done up first. I think you need to run out 250mls of fluid into a jar with clear pipe submerdged in fluid . My results will follow later to day .
Bleeding C3 Picasso clutch
Huskyxantia
- x 879
Re: Bleeding C3 Picasso clutch
Husky.
- x 8310
May you be all fully good and successful Husky
PaulC5
- x 667
Do not run out more than about 50 to 100 ml since any more and chances are it will drop to the reservoir outlet and then air will be in the pipes and cylinders and then you will have to start again. So once you have run about 50 ml out top up the reservoir before running any more out.Huskyxantia wrote: 03 Dec 2024, 07:50 Why some still insist the pedal should be pumped on the 2 clip system I don't know, plan for to day . Top up fluid level clip out no pumping.
Will try fluid bowl cap on & done up first. I think you need to run out 250mls of fluid into a jar with clear pipe submerged in fluid . My results will follow later to day .
Huskyxantia
- x 879
Husky.
