2001 xsara picasso hesitation.
Charlie715
Re: 2001 xsara picasso hesitation.
Unread post by Charlie715 »
Hi all, right i found the problem with the engine light... it was a 15amp fuse, Changed that, no more light or codes.
It does however still hesitate, even more so now its colder weather. Best way i can describe it is when warm, it stutters intermittently at certain speeds or if you hold the throttle at a certain point, then want more throttle it stutters. Yet when its cold, its like trying to pull away in 3rd.
I can get out of my road 10-15mph fine, yet go to accelerate out of the end of it, no matter how much throttle you give there is a 2-3 second delay then it picks up. I've also noticed the temp gauge wont go past 2 bars on the gauge, is that where it should be?
I've changed the plugs, air filter and put a bosch fuel filter in. Cleaned the MAP sensor, fitted a different coil pack incase the brand new one it came with was faulty, put some cataclean in it, atleast 3 doses of redex since i got it. It came with new charcoal filter and purge valve, and none of it has stopped the hesitation. Any other suggestions or obvious things? as i'm running out of candidates.
