Citroen C5 X7. Interior temperature hotter than the surface of the sun according to readings.
x 1083
Re: Citroen C5 X7. Interior temperature hotter than the surface of the sun according to readings.
Unread post by Rp0thejester »
Oh well, guess I'll just to live without cooling from now on.... isn't that why windows were invented? Keep an eye out for Transit drivers in winter they always have there window open. As an old transit driver I can tell you it takes ages to warm it up, once it's warm don't ever turn it down or you'll freeze, the window is your temperature regulater.
Bury
Unread post by Bury »
Hello. I have the same problem. Today I wanted to find, check and replace the right sensor, but unfortunately I am not able to locate it :/ Did you manage to solve the problem? Did you find the sensor? Regards!
